RE 4.5 Leaf Springs/ Stock Shackles - JeepForum.com
post #1 of 15 Old 06-12-2008, 08:05 AM Thread Starter
TreddyoXJ
1997 XJ Cherokee
I'm currently getting ready to replace my rear leaf springs with RE 4.5" leaf packs, as my current Rough Country springs are wearing out and I'm tired of the lift blocks being back there. Now, someday I plan on my lift amounting to 5.5", but I can't afford all of that stuff right now. My question is this: can I practically install those new RE 4.5" leaf springs with my stock shackles and just change the shackle length when I'm ready to lift it another inch, or is that going to cause complications of some sort? Also, does anyone have RE 4.5" springs that can tell me how much actual lift they achieve? Thanks!
2012 Jeep Wrangler Rubicon Unlimited in Dozer (stock)
SOLD: 1997 Jeep Cherokee Country w/D44, D30 w/ Aussie locker, Edge Trail Jammer System, 4.5" Rough Country lift, Zacatal Roof Rack, T&T front bumper, all lower body/bumpers/trim are Herculined, 31x10.5 MT Baja Claws, Warn 9.5ti. Ephesians 6:10-18
I HATE when people hijack threads. PM!
TreddyoXJ is offline
post #2 of 15 Old 06-12-2008, 10:12 AM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
Expect 5"+ out of those springs on your rig.
For reference, this is what the 3.5" RE leafs look like, brand new, with stock shackles. The tires on that rigs are 31x10.5s on 15x8" rims. I neglected to take measurements before installing the lift, but I'd estimate lift at 5.5" out of the 3.5" leafs. XJ was stock with no armor, roof rack, etc.
Personally I wouldn't run the RE 4.5" leafs with stock shackles.
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #3 of 15 Old 06-12-2008, 10:30 AM
jeepnphreak
1989 XJ Cherokee
that about where I sit with my re3.5 lift, I can get 33s under the rear no trimming and I still have a good 3-4 inch wheel travle, I ll need to trim just 1/4 inches back side of the front wheel well to allow for full lock/articulation,
so with re4.5" spring you should get very close to your wanted hight, I would also swap out the stock shackles after you have installed the 4.5s figure out how much more you want and go from there.
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper.
94 yj: stock everything and 4 angry squarrels under the hood.
jeepnphreak is offline
post #4 of 15 Old 06-12-2008, 07:54 PM Thread Starter
TreddyoXJ
1997 XJ Cherokee
Why, out of curiosity, do they do that? I mean, why don't they label that set of leaves for 5.5" of lift if that's what it really achieves?
Jason: on that set of leaves that on the pictured XJ, did they settle out after a while or did they stay like that for the most part? As I understand it, most of them do settle a little bit once they're under the car for a little while. I just want to avoid not having enough leaf spring when I got for a little more lift (not really wanting to buy another set in just a year or less).
The lift setups page didn't seem to help out with these questions very much.
post #5 of 15 Old 06-12-2008, 08:14 PM
asp87
RE leaf packs are known for coming stiff and sitting high out of the box but softening up and sagging after carrying heavy loads for an extended period of time. they eventually end up at about a half inch less than named, but flex really well. IMO, you should have no problem doing that. in fact, i was considering doing something similar. not sure of my plan of attack yet though.
98 XJ, perpetually on jackstands
asp87 is offline
post #6 of 15 Old 06-12-2008, 09:17 PM
gijazbo
i got a new set of stock dimention shackles when i put on my lift for added comfort of mind...... i like them thay are about 3 times as thick as the stock schackle and have a little more flex in them......hard to install a hitch though.
It sucks to own a jeep in NE Ohio
MOPAR.... Made Of Paper clips And Rubber bands
Originally Posted by WillysEdition04 View Post
After reading 7-8 of your posts I've come to the conclusion that you may be mentally retarded, which is why I won't ask what "brain guts" are.
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
My build thread:
gijazbo is offline
post #7 of 15 Old 06-13-2008, 12:07 AM
EricsXJ
The Post man
EricsXJ's Avatar
Originally Posted by TreddyoXJ View Post
can I practically install those new RE 4.5" leaf springs with my stock shackles ...?
You can, and I have done it but I don't recommend it.
It will be hard to install.
The ride will be stiff.
It will not flex well.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #8 of 15 Old 06-13-2008, 01:05 AM Thread Starter
TreddyoXJ
1997 XJ Cherokee
In that case I'm going to avoid it. Looks like I'll spring for the 3.5"... pun intended.
post #9 of 15 Old 06-13-2008, 01:13 AM
TwistedcaB-
1991 XJ Cherokee
i have a 4.5 spring pack and stock shackles on mine. the only thing is i wish that i had a longer shackle is the bolt hits the " frame" when it's allthe way forward and then the hitch when it's bottoming out ( rare ) mine gets a bit of air...
TwistedcaB industries
1991 XJ. 8" lift, 35" BFG KM2's. the new project
1990 XJ. 6.5 lift, 33" BFG ATKO's. SOLD : (
TwistedcaB- is offline
post #10 of 15 Old 06-13-2008, 09:10 AM
Vendor
1995 XJ Cherokee
Because it won't achieve that on everyone's rigs because they'll weigh different amounts depending on what all you've got on the rigs. Some mfgs design their springs for "stock" XJs, others design them for modified XJs that have aftermarket bumpers, winches, rocker guards, skid plates, etc. All that aftermarket steel packs on the pounds. Big spare tires pack on the pounds. I gain about 1/2" of lift in the back if I take my spare tire (~90 lbs) off.
Big difference in sprung weight between this rig:
And this rig:
That white XJ netted the same mount of lift with the RE 3.5" leafs, stock shackles, and RE 4.5" coils as my rig got with RE's full 5.5" kit (4.5" leafs, 1.25" shackles, and 5.5" coils).
So without having a bunch of different springs and having to go over vehicle weight, how much gear they carry, etc with every customer every time they order a lift kit (which is what we have to do with Old Man Emu lift kits), which is better... to design a set of springs around the stock weight of an XJ, then have a lot of folks with modified XJs complain about not getting the advertised amount of lift, or design the springs for an average modified XJ and have some folks get more lift than advertised? Folks generally don't mind getting "more" than what they paid for, but they sure don't like getting less.
Jason West -
post #11 of 15 Old 06-13-2008, 10:20 AM
winkosmosis
When they say 1" shackle, does that mean it is 1" longer or that it adds 1" at the axle?
Atheist Jeep Club member #3
Non-Astrologist Jeep Club member #?
Pull the Socialist Plug on Old People Jeep Club member #1
winkosmosis is offline
post #12 of 15 Old 06-13-2008, 10:48 AM
Vendor
1995 XJ Cherokee
It almost always means they add 1" of suspension lift.
Jason West -
post #13 of 15 Old 06-13-2008, 05:17 PM Thread Starter
TreddyoXJ
1997 XJ Cherokee
And this rig:
Well, that kind of complicates things for me. In the end, I'm going to basically have an RE 5.5" kit (which comes with the 4.5" leaves) with T&T long arms. So I want those springs, but they don't seem to work well, in the opinions of others, at the 4.5" lift level. For now, I need at new set of leaf springs because mine are totally crapped out... they work, but their days are surely numbered. So I still don't know what to do. I'm not totally opposed to have a rough ride with 4.5" leaves (after all, my Rough Country springs definitely lived up to their name ), but I also don't want to have my a$$ end sticking up like a skunk until my new lift is in. I don't know.
post #14 of 15 Old 06-13-2008, 05:26 PM
Vendor
1995 XJ Cherokee
So go with the RE 3.5" leafs. If you end up going taller, just run the RE or TREKS (T&T) 1.5" lift shackles.
Jason West -
post #15 of 15 Old 06-13-2008, 05:26 PM
XJLI
XJLI's Avatar
1993 XJ Cherokee
TNT LAs work fine at 4.5" of lift. IIRC the min for them is 4." Even with a heavy bumper, a 3.5" RE leaf with a 1-1.5" shackle will keep you at 4-5" of lift.
Factory Four Link
XJLI is offline
Replacing stock leaf springs, need some info shawnzoman XJ Cherokee Technical Forum 4 12-11-2009 09:42 AM
Question about stock leaf springs xjpilot XJ Cherokee Technical Forum 4 07-30-2007 03:13 PM
Anyone do a recent lift and still have their stock leaf springs. rapom XJ Cherokee Technical Forum 6 08-06-2006 04:41 PM
stock rear leaf shackles trailblaze XJ Cherokee Technical Forum 1 02-12-2006 11:28 AM
Stock Length Leaf Shackles Thayer XJ Cherokee Technical Forum 3 05-25-2005 12:12 PM
