RC shackle relocation TOO high....suggestions? - Page 2 - JeepForum.com
post #16 of 53 Old 08-24-2013, 07:45 PM
rugsucka
Originally Posted by cory4um View Post
Well, you can't just throw spacers on and call it a day...
Your still lifting a jeep and now your steering, drivetrain and handling components are all out of whack. If everything on his jeep is adjustable, thn maybe he can get away with it. But still would require a ton of adjusting and /or replacing of some other components..
Thanks tips.
I wasn't suggesting that's all it would take, I was suggesting to just lift it to 4-5" and leave the rear alone.
rugsucka is offline
post #17 of 53 Old 08-24-2013, 08:03 PM
cbenez1
Originally Posted by HiDefXJ View Post
I have yet to test drive it so I dont know if there are any vibes but unfortunately,I have pulled all the tricks out of the "bag" (shims and TC drop) so I don't know what I will do if they arise.
Hell get out there and drive it then. You may already have vibrations to work out.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #18 of 53 Old 08-24-2013, 08:23 PM Thread Starter
HiDefXJ
True, it needs to be done, but I still need to torque the shackles and it was late when I packed it in last night.
But the vibes isn't the issue, it's the hot rod like stance that is bothering me.
HiDefXJ is offline
post #19 of 53 Old 08-24-2013, 08:46 PM
Motorcharge
It'll settle over time. Mine took about 3 weeks to settle in after install. Dropped down about a half inch.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #20 of 53 Old 08-25-2013, 03:12 AM
sAe23
1995 XJ Cherokee
Your pinion is too high for use with standard U-joints at the T-case end.
What degree shims did you use? The relocation brackets add to the pinion angle, so you may not need the shims.
Without a SYE / DBL Cardan drive shaft, the T-case output shaft and the pinion should be parallel.
(REF: http://www.4crawler.com/4x4/CheapTri...n-Measurements)
As for the "hot rod stance", some people here think it improves the aerodynamics
sAe23 is offline
post #21 of 53 Old 08-25-2013, 09:32 AM Thread Starter
HiDefXJ
Seems to me that if the u joint angles matched when at rest, then there would be a greater possibility of binding/breaking when the rear is dropped down.
I need to analyze that link you sent me closer, its a lot to absorb in one sitting.
As for the shims, I feel like they were 2 * shims, but that may be inaccurate. It was 3 years ago that they were installed.
HiDefXJ is offline
post #22 of 53 Old 08-25-2013, 11:25 AM
ibjeepin95
Go back to a stock pack and 2" shackle. Done.
ibjeepin95 is offline
post #23 of 53 Old 08-25-2013, 04:10 PM Thread Starter
HiDefXJ
Forgive my ignorance, but what is a "stock pack"?
HiDefXJ is offline
post #24 of 53 Old 08-25-2013, 04:35 PM Thread Starter
HiDefXJ
I'm to the point now that I am ready to remove the RC relocators and replace them with 1-2inch shackles but then I remember why I went this route in the first place, the rear sag and the shackle clunk.
Everyone says boomerang shackles suck, no one condones cutting and folding the shackle housing out of the way. If I put extended shackles on, I will still have the clunk.
Grrrrr......
HiDefXJ is offline
post #25 of 53 Old 08-25-2013, 05:18 PM
Motorcharge
Remove a leaf from the 3" packs and get 1" shackles. Boomerang shackles should be ok on the relocators, they just suck on the stock location. You don't want 2" shackles in the stock spot, they put way too much stress on the leaf packs and you get a damn near vertical shackle angle.
|SOLD|
| June 2015 COTM |
post #26 of 53 Old 08-25-2013, 06:31 PM Thread Starter
HiDefXJ
Thanks for all of your advice. I am going to remove the relocators and go with 1 inch shackles and see where I stand. I doubt I will remove a leaf and I will probably deal with the passenger clunk. Maybe even cut and fold the rear of the shackle housing.
Hopefully this will also cure some of my driveline angles.
HiDefXJ is offline
post #27 of 53 Old 08-26-2013, 06:39 AM
cbenez1
If you decide to not use the relocators, I call dibs on them if you want sell them. Seriously pm me if want to sell them. Hope the change works for you.
cbenez1 is offline
post #28 of 53 Old 08-26-2013, 08:56 PM Thread Starter
HiDefXJ
I will let you know if it comes to that.
HiDefXJ is offline
post #29 of 53 Old 08-27-2013, 09:28 AM
Azzy
Ive had a lot of noise and a rough ride from a very similar setup. I found the RC brackets to be hitting shackles... weather I went with stock ones or with extended. They tend to force your springs flat if you use the rear 2 holes, and bring the rear end up high if you use the others. Im figuring on keeping them, but plan on moving the lift up a bit so they would factor in correctly.
I will say the amount that the SRB allow the back to droop is impressive.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #30 of 53 Old 08-27-2013, 11:28 AM Thread Starter
HiDefXJ
I really believe that these brackets are intended for people who have stock leaf springs that are experiencing sag.
My findings anyway....
HiDefXJ is offline
