Rattle When Driving and Death Wobble at 55mph. - JeepForum.com
post #1 of 4 Old 02-23-2012, 10:02 PM Thread Starter
RHolbrook609
1995 XJ Cherokee
I have a 1995 Jeep Cherokee. Last month, I started getting a wierd rattle sound when driving. It only happens when the wheels are in motion. It stays rattling when I put it in Neutral to. Then on top of that, my Jeep now gets a death wobble only at 55mph. If it is below it, it doesnt wobble and once it is over it stops wobbling. Anybody out there that can tell me what I need to do to get this rattle sound gone and the death wobble!?!?!?! Thanks!!!
Ryan Holbrook
RHolbrook609 is offline
post #2 of 4 Old 02-23-2012, 10:05 PM Thread Starter
RHolbrook609
1995 XJ Cherokee
Also forgot to mention that the rattle sound gets worse as the tires spin faster.
Ryan Holbrook
post #3 of 4 Old 02-23-2012, 10:08 PM
mgold1981
1992 XJ Cherokee
Could be as simple as some mud stuck in one of your wheels throwing off the balance of your wheel, so I would start by checking that. Have your wheels and tires balanced and inspect your tires- could have a belt separation. Could be something involving your drive-shaft(s), so check them also. Have your front end and suspension checked out also.
I had pretty radical "death wobble" after installing a 2" BB lift but it went away with new tires and an alignment.
mgold1981 is offline
post #4 of 4 Old 02-27-2012, 12:49 PM
MckayMan
You are not alone. I have had the same death wobble start up a few months after my 2.5" OME install. I have my tires rotated and balanced every year, and check the pressure in every tire once a week. (35 psi)
The death wobble scared the bee-gees out of me.
2001 Cherokee 4x2
4 Door Limited
4.0L (62mm TB) - Bank's Headers.
140K Miles
2.5" OME lift.
MckayMan is offline
death wobble , rattling
Wobble in front, NOT death wobble, and yes I got the tires balanced 614XJ XJ Cherokee Technical Forum 10 09-26-2012 05:55 AM
High Speed wobble, but not death wobble Schmuckingham XJ Cherokee Technical Forum 10 04-30-2012 07:27 PM
wobble at 55mph ckisela XJ Cherokee Technical Forum 20 08-26-2010 11:40 PM
violent wobble at 55mph!!??!! 98redXJ XJ Cherokee Technical Forum 2 02-24-2010 05:02 AM
Death Rattle of Death: Part Deux BurlySurly XJ Cherokee Technical Forum 3 01-11-2005 12:55 PM
