random high idle - JeepForum.com
post #1 of 5 Old 02-23-2009, 07:49 PM Thread Starter
amsoilman
1965 CJ6
random high idle
ok so a few days ago i started my 87 XJ and it was idling high (no tach so dont know what rpm's) and was high while driving. turned it off and when i started it again it was fine. well today when i got off work it was idling high so i pulled over and shut it off, started it up again and it was fine.
im thinking maybe TPS?? i dont really think its a vaccum issue since its like a week or so in between and doesnt fluxuate while running.
AMSOIL DEALER
amsoilman is offline
post #2 of 5 Old 02-23-2009, 07:52 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You may need to remove the IAC, and clean the pintle with throttle body cleaner. If you do be careful with the pintle, and don't push or pull on it.
xjfever is offline
post #3 of 5 Old 02-23-2009, 07:56 PM
Ridin' Around
get yourself a can of Power Foam and run through it.
Ridin' Around is offline
post #4 of 5 Old 02-23-2009, 07:56 PM Thread Starter
amsoilman
1965 CJ6
ill check that out also, i planned on cleaning the throttle body also tomorrow (just as a maintenance thing, not to fix this problem)
AMSOIL DEALER
post #5 of 5 Old 02-23-2009, 08:23 PM
tangofox007
I agree. Next time it revs up, try unplugging the flat TPS connector. If the rpm drops, you will know what the problem is. (Sometimes the problem is a poor connection at that connector.)
tangofox007 is offline
Random High Idle when A/C is on? RamboPants XJ Cherokee Technical Forum 15 08-12-2013 06:31 PM
couple random questions...high idle and door panel? jackdup XJ Cherokee Technical Forum 4 12-20-2008 07:40 AM
Random Idle Revs elevated XJ Cherokee Technical Forum 4 12-06-2008 01:54 PM
Random engine stall at low/high speeds and random missfire cswetnam XJ Cherokee Technical Forum 4 06-20-2008 05:54 AM
random low idle/stall problem ianb XJ Cherokee Technical Forum 16 12-10-2006 09:33 AM
