Random engine stall at low/high speeds and random missfire - JeepForum.com
post #1 of 5 Old 06-19-2008, 11:59 AM Thread Starter
cswetnam
After reading a lot of posts on here, not sure if I found one w/ my exact "bundle of issues." If so, point me in the direction.
99 xj, 4.0L, 190k miles.
Symptoms: In park - slightly rough idle but it maintains the 900rpm with a little wavering back and forth(approx. 20rpm). In drive @ a stop - slightly rough idle with strong, random lope in the idle. Sometimes when this lope occurs, engine will stall. Sometimes not. Engine always starts right back up.
Engine will randomly stall when decelerating @ any speed. 70 mph and let off the gas, engine stalls. Coming to a stop, engine stalls. This will happen 3-4 times a week, completely random. Engine always starts back up.
I think I've got a stalling issue and a missfire issue.
I've replaced the rotor tip, plugs, wires. Still have the miss. Kept the Distr. cap because the miss is completely unbias to weather.
I've replaced the entire fuel pump module and inspected the tank. Still have a stalling issue.
I also have no CEL or error codes to speak of. Any ideas of where to start?
cswetnam is offline
post #2 of 5 Old 06-19-2008, 02:00 PM
jeepme95
Clean and check your throttle body, and IAC. Could also be your CPS which is a pretty common problem and has many of the issues that you are describing. I didnt think a 99 had a distributor cap.
95 XJ 6.5" of long arm lift, locked, 35's, warn/dutchman axles.
jeepme95 is offline
post #3 of 5 Old 06-19-2008, 03:30 PM Thread Starter
cswetnam
99 was the last year of the distributor cap. '00 went to the ignition coils.
Question on the IAC, I have MPI fuel rail. Would the IAC be down by the intake manifold? Not sure where to look. Thanks.
cswetnam is offline
post #4 of 5 Old 06-19-2008, 05:49 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
What brand/type of plugs did you install ? The Jeep 4.0 doesn't run well with SplitFire or Platinum type plugs. Most Jeep owners use just the plain Champion plugs and get good results.
Use a can of fuel injector cleaner in the next three tanks of gas. Buy the good stuff like SeaFoam or Chevron Techron. - http://www.chevron.com/products/ourf...tives/tcp.aspx -
Clean the IAC.
There are 3 sensors on the 1997-2001 throttle body -
Bottom - MAP sensor
Middle Right - Throttle Position Sensor (TPS)
Top - Idle Air Controller (IAC)
CJ7-Tim is offline
post #5 of 5 Old 06-20-2008, 06:54 AM Thread Starter
cswetnam
I just put in motorcraft plugs. I'm not super excited about them, but with all of my other issues, it's hard to tell if they're performing as required.
Just pulled the IAC and am in the process of cleaning off the carbon and some junk that's down within that spring loaded metal sleeve. I'll put it back on tonight and change my distributor cap as suggested before. I already have Seafoam on the shelf (love that stuff) to dump in my tank. I'll report back in a day or 2 w/ what I've found. Thanks.
cswetnam is offline
Random High Idle when A/C is on? RamboPants XJ Cherokee Technical Forum 15 08-12-2013 07:31 PM
random high idle amsoilman XJ Cherokee Technical Forum 4 02-23-2009 09:23 PM
Random hesitation issues - highway speeds/idling rootster XJ Cherokee Technical Forum 3 10-28-2008 11:16 AM
Random Stall and Won't Restart? bhanse4 XJ Cherokee Technical Forum 2 06-26-2008 11:55 AM
random low idle/stall problem ianb XJ Cherokee Technical Forum 16 12-10-2006 10:33 AM
