Rampage Housings/Upgraded Harness Writeup - And A Fix For Some of You!! - Page 2 - JeepForum.com
post #16 of 24 Old 12-25-2012, 11:40 AM
jbudz511
Question. This may be totally amateur but I am fairly new to DIY projects and jeeps in general. I just received the Rampage headlights as well as the eautoworks harness for Xmas
So heres my question, I was able to follow this write-up, my only question is do you have to do anything with the relays or the red wires? In the write up you only mention the grounds the plugs? Thanks for the help, I can't wait to install them
jbudz511 is offline
post #17 of 24 Old 12-25-2012, 11:14 PM
bdheaton
Junior Member
Relays and Red Wires.
The relays can be mounted anywhere secure and convenient. The red wires need to go to a power source, preferably through an appropriately sized fuse if one isn't part of the harness. You could go either directly to the battery, off the PDC, or some other location.
The plug going into the factory headlight socket energizes the coil of the relay when you turn on the headlights. The red wires bring power into the relay contacts which are switched by the coil. The other side of those contacts goes to the new headlight connector.
-BDH
bdheaton is offline
post #18 of 24 Old 12-26-2012, 07:07 AM Thread Starter
TPI Monte SS
-BDH
Indeed. I mounted the relays on the inner fender behind the battery (near the fuse box, IIRC), and connected the power lead directly to the battery since the harness is fused. Good luck with your install!
Steve Ragusa - North Jersey
'01 XJ - SOLD!
'06 Infiniti G35x - coupe front springs, tint, FX35 18's, hitch for the bike rack.
'03 KJ Limited -WifesJeep- 3.7, Auto, NP 242, '06 Limited 17's. 50K original miles.
TPI Monte SS is offline
post #19 of 24 Old 12-26-2012, 08:33 AM
jbudz511
Did you make a new hole for the relays or did you use one that was already there. There is a bunch of different sized holes around that area that seem suitable that I used. I haven't connected the power lead yet. How would you go about doing that lol. Like I said, new to DIY and cars and stuff. I feel like a metal tool going onto the battery terminal is bad news bears...thanks for all the help guys
jbudz511 is offline
post #20 of 24 Old 12-26-2012, 08:52 AM Thread Starter
TPI Monte SS
Ah, I didn't realize you were that new to wrenching. I used existing holes in the radiator support behind the headlights, no extra cutting. You have to disconnect the ground wire on the battery first - that's the black one. Once that's off, there's no electricity running through the Jeep and you won't get shocked. Then you can connect the red power wire from the headlight harness - use a ring terminal crimped onto the end of wire and attach it to the battery at the clamp. Something like this -
'01 XJ - SOLD!
post #21 of 24 Old 12-26-2012, 09:04 AM
jbudz511
Ok awesome thank you got your help and bearing with my lack of knowledge lol
jbudz511 is offline
post #22 of 24 Old 12-26-2012, 05:39 PM Thread Starter
TPI Monte SS
No problem, we all gotta start and learn somewhere! Good luck with it, and let us know if ya need more help!
'01 XJ - SOLD!
post #23 of 24 Old 12-27-2012, 05:27 AM
Shobie
I put in the Rampage lights and they work great! The only problem I have is aiming them can be a little tricky.
I built my own wiring harness, very easy to do, and I don't have the problem of lights staying on. There must be a design flaw in the harness everyone is buying if lights are staying on after you turn off your light switch.
Shobie is offline
post #24 of 24 Old 12-27-2012, 10:44 PM
jbudz511
There's nothing wrong with mine! The lights turn on and off like they normally did. And they seem to new aimed perfectly. How do you go about aiming them anyway?
jbudz511 is offline
2 questions about upgraded Wire Harness louisd11 XJ Cherokee Technical Forum 2 06-10-2009 05:25 PM
Where to ground upgraded harness Me007gold XJ Cherokee Technical Forum 5 05-04-2009 08:53 PM
Upgraded Headlight Harness sublime600 XJ Cherokee Technical Forum 4 05-30-2008 11:34 PM
Upgraded wiring harness dakotajeep XJ Cherokee Technical Forum 15 11-08-2007 11:25 AM
DIY Upgraded Headlight Wire Harness? DefaZ XJ Cherokee Technical Forum 2 04-19-2004 07:40 AM
