Well I dont have a diagram but if you have a voltmeter and a 9 volt battery you can figure out what wires go where easily. Use the volt meter to figure out witch wire has power with the ignition switch off thats what keep your radio from resetting everytime you shut it off, then turn the key on and find the wire that now has power, black is normally the ground. As for the speakers get to a quiet area and take your 9 volt battery and touch the wires to the positive and negative terminals and you will hear your speaker buzz then you can locate what wires go to each speaker. hope this helps.
