Radio static - JeepForum.com
post #1 of 11 Old 10-31-2013, 08:10 PM Thread Starter
blue96jeep
Radio static
i have static in my speakers at mid volume. I thought it was the antenna so I tried my iPod and CD. Its still there.
Backstory
when it first happened I thought the speakers were going bad because they were 11 years old, I figured time for an up grade, got new speakers and put them in. static still there and then the head unit crapped out, so I replaced it. Static is sill there. I even removed the radio antenna wire from the back of the head unit and used my iPod, static is still there.
any ideas on what could be causing it?
blue96jeep is offline
post #2 of 11 Old 10-31-2013, 08:13 PM
Soldier905
1988 MJ Comanche
Try cleaning the grounds and the connections .
Soldier905 is offline
post #3 of 11 Old 10-31-2013, 08:23 PM Thread Starter
blue96jeep
I cleaned both the grounds in the engine compartment with no real help I can't find the ground for the radio harness
post #4 of 11 Old 11-01-2013, 08:20 AM
CCKen
CCKen's Avatar
Which "Both Grounds" in the engine bay?
CCKen is online now
post #5 of 11 Old 11-02-2013, 04:09 PM Thread Starter
blue96jeep
the ground from the engine block to the fire wall and then the ground from the negative battery terminal to the fender
post #6 of 11 Old 11-02-2013, 04:36 PM
Roler
In my 97 post update, the strap-like ground from the rear of the block to the firewall IS the radio static interference ground (or whatever its official name is). If you have this too, you might want to replace it. Other possibility would be loose connection/wires.
Roler is offline
post #7 of 11 Old 11-02-2013, 05:33 PM
CCKen
CCKen's Avatar
Here's a test you can perform to see if the bonding strap to the engine is a good connction. I know you cleaned this bonding but you may want to try the test anyway, just to say you did.
96 + XJ Body Ground Connection Test
This test checks the condition of the vehicle body ground connection (Braided cable on firewall to engine cylinder head bolt). This test should be performed with the battery positive cable removed from the battery.
Start: Disconnect both battery cables, the negative cable first, then the positive battery cable. Reconnect the battery negative cable and perform the test as follows:
(1) Connect one ohmmeter test lead to the vehicle fender. Connect the other test lead to the battery negative post.
(2) The resistance should be less than one (1.0) ohm.
(3) If the resistance is more than one ohm, check the braided ground strap connected to the engine cylinder head and the vehicle body for being loose, corroded, or damaged. Repair or replace the ground strap connection and replace bolt at firewall connection or nut at engine cylinder head bolt connection, if required.
Finish: Disconnect the negative battery cable. Reconnect positive battery cable, and then connect the negative battery cable.
CCKen is online now
post #8 of 11 Old 11-02-2013, 05:40 PM
CCKen
CCKen's Avatar
Other places to look for radio interference potentials are: Radio antenna base ground, Radio receiver chassis ground wire or strap, radio suppression-type spark plug wires, and the distributor rotor tip erosion. Other body components with poor grounds may cause interference, such as the HVAC Blower motor, alternator, and wiper motor.
CCKen is online now
post #9 of 11 Old 11-02-2013, 06:40 PM
Roler
I now recall it was you CCKen, when I remembered those nice pics of all the engine bay grounds
Roler is offline
post #10 of 11 Old 11-02-2013, 08:33 PM
CCKen
CCKen's Avatar
Hope those pics helped you.
CCKen is online now
post #11 of 11 Old 11-02-2013, 08:37 PM
WBZ
1997 XJ Cherokee
I seem to recall a problem like this on a diesel Toronado many years ago. My starter was loose>
WBZ is offline
