Radio and Lock trouble - JeepForum.com
post #1 of 5 Old 02-14-2011, 06:59 AM Thread Starter
CGinWI
First question,
The front speakers did not work when I got my XJ last July. I've been busy working on other things but this last weekend it was time to work on them.
I have read that it was most likely a broken wire in the door bellows.
I ran new wires and when i hooked them up the speakers worked, for about
10 seconds then a pulsing noise starts. I unhooked for a minute then hooked up again, 10 seconds later the pulsing again.
What could it be ?
Second question,
I opened my rear hatch this weekend and closed the hatch and the lock solenoid starts going nuts for a couple of minutes and has been almost every time i work the handle or shut the door. Door works fine. I also found out that now I can't lock my doors, not with the key fob or manual with the switch on the door. Would just replacing the solenoid fix ?
Thanks for any help you can give !!
CGinWI is offline
post #2 of 5 Old 02-14-2011, 08:54 AM
Northernsun
Northernsun is offline
post #3 of 5 Old 02-14-2011, 08:55 AM
Northernsun
same issue(kind of)
Mine too. The speakers dont work, and I have seen what the cause is, just havent fixed it yet. My questions is, what kind of impedence does your ne wspeaker wire have? If it not very good, you could be getting some residual voltage from another wire that is freyed in the door elbow. May have to look at everything in there to be sure thats not the issue.
On the issue of the rear hatch, sorry to hear that. Mine just doesnt work(its loose) and I hope thats the only issue. The guy I got it from has a rope inside to pull it open. I will get to it when the weathers warmer.
You should always be careful. If you're not then someone else won't be, and things are always much, much worse when they happen to you.
post #4 of 5 Old 02-14-2011, 12:08 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
2nd ? first, I would guess you have a short circuit in the hatch wire harness that is making the solenoid misbehave. Inspect the wires in and near the rubber boots by the hinges. If those are OK, take the plastic trim panel off and inspect the wires, wire connector, and the solenoid in the hatch. Once you have that fixed you might find that the speakers work right.
Describe how you hooked up the speaker wires, what type of wire you used, and where you made the connections on both ends of the wire. As suggested, inpsect the other wires in the door wire harness for chafed insulation or other damage.
CJ7-Tim is offline
post #5 of 5 Old 02-15-2011, 05:33 AM Thread Starter
CGinWI
Tim,
I cut the speaker wires a couple of inches before they go into the door bellows.
I forget to mention that I did touch the wires to the speaker where I cut them and it did the same thing.
I used the spade connectors at the speaker, I think I used 12ga wire, I know that's over kill but its what i had lying around. The other connections are getto,
twisted together and electrical tape.
CGinWI is offline
Radio lock box in XJ? magnumcherokee XJ Cherokee Technical Forum 10 12-24-2009 11:50 AM
Buddies XJ keeps blowing radio, domelight, and power lock fuse FrankTheDank XJ Cherokee Technical Forum 1 06-29-2009 07:48 PM
Trouble removing ignition lock cylinder dangerdan07 XJ Cherokee Technical Forum 2 12-21-2008 09:21 AM
Front Passenger Door Lock Trouble Dickydubs XJ Cherokee Technical Forum 4 01-25-2007 06:24 PM
How do i lock 2 piece axle after removing vacuum lock e Vavso XJ Cherokee Technical Forum 4 12-11-2001 07:26 AM
