Radio antenna went bad? How to replace it? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Radio antenna went bad? How to replace it?
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineORS Recovery RopeSynthetic Winch Rope from ORS
Unread 08-12-2005, 03:05 PM   #1
skyjacked94xj
My radio antenna is bad somewhere. I took the plug out from the head unit and put a different antenna in the hole and it played perfectly.. So that tells me i need a ned antenna or cable.. My question is how in the hell do you get the antenna out or get to the cable? I tried pulling the dash apart near the glove box but the box is pop rivoted on.. Any suggestions?>\
DAILY DRIVER
1996 Cherokee Classic
4.0HO 5-SPEED! | 16x8 Rucicon Moabs | lowered 1" | clear corners | silverstars | custom waggy taillights | custom intake | Aem TB spacer | Dynomax cat-back | Bored TB | FirePower Ignition Kit
CLASSIC TOY
1968 Chevy C-10 short bed
Chevy 350 crate motor | 4-speed | fully restored | Lowered | 20" Centerline Daggers.. wayyy too much to list
Project
1988 Pontiac Trans Am GTA
350 TPI | WS6 | 48k original miles | Flame Red Metallic
SOLD: 94 cherokee | Lifted | Locked
SOLD: 97 TJ | 33's | 4.56's | :(
Searching for an Ls-1 Rx-7 project....
skyjacked94xj is offline   Reply With Quote Quick reply to this message
Unread 08-12-2005, 03:28 PM   #2
tangofox007
Is the antenna fixed or powered?
In either case, to get to the antenna base, you will need to partially remove the rubber liner inside the wheel well below the antenna. The cable enters the cabin behind the passenger kick panel, then is routed under the dash to the radio.
tangofox007 is offline   Reply With Quote Quick reply to this message
Unread 08-12-2005, 04:20 PM   #3
andromeda
i have a 2000 XJ with regular non-powered antenna and it unscrews from the base on top of my fender.
andromeda is offline   Reply With Quote Quick reply to this message
Unread 08-12-2005, 05:20 PM   #4
anony91xj
The chances of the antenna itself going bad are approximately none, unless it snaps off or something...it's just a metal rod. The wire's most definitely broken somewhere.
1998 VW GTI 2.0
anony91xj is offline   Reply With Quote Quick reply to this message
Unread 08-12-2005, 10:01 PM   #5
skyjacked94xj
well i am going to the junk yard tomorrow and i'm going to fool around there with some jeeps and see the easiest way to hack it out of there.. thanks for your help.
DAILY DRIVER
CLASSIC TOY
Project
Unread 08-12-2005, 11:56 PM   #6
wehtjns
I had the same problem, there is a break in the connection of the antenna wire.
Try this, look in the interior need the passengerís feet, there is a triangle piece of plastic under the dash . Its held there by one screw, remove this. You should now see the antenna wire that come out of the fender wall and there should be a connector that connects it to another section of wire that goes up into the dash and to the radio. This connector is spring loaded and over time the connector breaks under the pressure of the spring. Remove the spring and duck tape the connector back over the wire. It makes more scents when you get in there.
wehtjns is offline   Reply With Quote Quick reply to this message
Unread 08-13-2005, 07:21 AM   #7
skyjacked94xj
I am going to go check that now
DAILY DRIVER
CLASSIC TOY
Project
Unread 08-13-2005, 10:16 PM   #8
skyjacked94xj
Thank you sooooo much. Thats exactly what is was.. Thanks for everyones input
DAILY DRIVER
CLASSIC TOY
Project
Unread 08-15-2005, 06:12 AM   #9
Brighton Jeeper
I'm getting poor radio reception in my daughter's 2000. We just had an after market radio installed a few months ago. I need to check and see if there is a connector such as this in this model year also.
2000 Cherokee Classic
2001 Cherokee Limited
2002 Liberty Sport
Brighton Jeeper is offline   Reply With Quote Quick reply to this message
Unread 08-15-2005, 08:32 PM   #10
jeepsterwannabe
does this apply to the 1990 Xj with power antenna? i cant seem to find the triangle peice...
'90 4dr XJ
DEAD,totaled in the prime of life
new jeep, 00 Grand Cherokee, 2WD (i know..)
jeepsterwannabe is offline   Reply With Quote Quick reply to this message
Unread 08-16-2005, 04:08 PM   #11
skyjacked94xj
i am sure it does apply to the the power antenna.. my case was with a fixed antenna.. But the triangle piece is the piece of plastic that would be directly beside your feet if you were sitting in the passengers seat.
Unscrew that rocker panel plastic and then unscrew another screw holding the triangle piece in and pull the piece... Then the antenna connecter should be right there. LEt me know if you have any questions.
DAILY DRIVER
CLASSIC TOY
Project
Unread 08-16-2005, 08:30 PM   #12
tangofox007
My '88 with power antenna has no such part. FWIW.
Unread 06-25-2012, 10:54 PM   #13
adammendelsohn
1990 XJ Cherokee
I'm getting wobbly reception as well...sometimes it's good though...is this the spring loaded connector? If it is, you recommend pulling it apart and taking out the spring? What do you do, just pull hard to get the spring out?
Also, I don't have a rubber panel under the fender that I can see to get to my antenna. I can't tell if it's an electric motor antenna or not. Should it be obvious if it is?
adammendelsohn is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 09:42 AM   #14
jdn3246
1994 ZJ
Is this true on a 1994 jeep grand cherokee ZJ/ Laredo as well because my radio wotrks but i just get no signal from the antenna
jdn3246 is offline   Reply With Quote Quick reply to this message
