radio antenna no signal - Page 2 - JeepForum.com
post #16 of 22 Old 04-04-2013, 08:15 AM
habbyguy
Kudos to the OP for offering up this solution "just to make things better". That's what makes this forum such a great one.
I recently bought a VW Jetta for a looooong road trip (really don't wanna do 7,000 miles in the XJ or put that kind of miles on my BMW), and had to do some work on it. So I joined the biggest VW forum around and started asking questions. 80% of the time, there's no response to tech questions. There is a load of misinformation that gets communicated and not corrected, and in general it seems like "you're on your own" if you have an odd problem (which I do, and which I've had to work out solo). I guess it's a difference in the typical driver of each vehicle - the XJ pilot does so because he (or she, occasionally...) is enthusiastic about the off-road potential, and sees the vehicle as an extension of his lifestyle. I guess the Jetta driver buys it because he wants to turn the key and get somewhere. Sigh.
The only better forum I've found is the GMC motorhome (1973-78) forum where every possible tech question is pounced on by at least several others who have "been there, done that". Those guys go really deep, but I guess that comes from the peculiar thrill / pain of owning and driving 12,000 pound antique hot rods with plumbing. ;-)
habbyguy is offline
post #17 of 22 Old 05-12-2013, 03:11 PM
Ohio96Jeep
96 XJ Radio Antenna Reception Fix
I just did the repair outlined in this post and it worked perfectly. 2 Screws is all I had to remove, the others were already taken out. Just a screwdriver, 30 seconds and done. I took the spring out of the connector. Taped the connection with electrical tape. Plan on never needing to do the repair again. Thanks to the original poster.
Ohio96Jeep is offline
post #18 of 22 Old 05-13-2013, 08:41 AM
xjpro
2001 xj
Would a 2001 XJ have this connector as well?
Mine is suffering exactly the same symptoms of poor radio reception.
Where should I look for the connector?
Thanks
xjpro
01 xj limited
ZJ rear disc brakes with working parking brake
Electric fan conversion with spal fan controller
xjpro is offline
post #19 of 22 Old 05-14-2013, 08:51 AM
Ohio96Jeep
Antenna connector location for poor reception
It should be in the same location, behind the side panel on the passenger side. Should be a couple of screws holding the trim piece on and thats about all you need to do is remove the trim piece, connector will be right behind it.
post #20 of 22 Old 05-17-2013, 03:26 PM
xjpro
Checked my antenna connection and everything looks tight, but still poor reception.
What should I look for??
Thanks.-
xjpro
01 xj limited
xjpro is offline
post #21 of 22 Old 11-16-2013, 10:51 AM
Afro
Guest
Posts: n/a
great fix
After years of only getting poor reception on one local station I'm now getting every station clearly. went out after reading post and fifteen minutes later had radio again. I twisted out the spring which was pushing connection apart, put the sleeve back over the two ends and used electrical tape to hold together. Works great! Thanks.
post #22 of 22 Old 01-15-2014, 04:48 PM
lokithecoyote
I have got to try this out when I get home...and to think I almost replaced the whole antenna mast before trying this.
The time you enjoy wasting is not wasted time.
lokithecoyote is offline
Awesome radio reception. Antenna or radio? sparkchaser XJ Cherokee Technical Forum 20 01-16-2008 08:43 AM
Radio Antenna xjarchaeologist XJ Cherokee Technical Forum 12 07-25-2006 01:16 AM
No FM radio signal okcjeeper XJ Cherokee Technical Forum 11 04-27-2006 09:30 AM
Radio Antenna tangofox007 XJ Cherokee Technical Forum 6 07-11-2005 07:20 PM
No radio signal dbltapp XJ Cherokee Technical Forum 3 07-21-2003 09:08 AM
