Quantcast radio antenna - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > radio antenna
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 10-01-2001, 09:49 AM   #1
matiebelle
radio antenna
I have a 93 Cherokee. The radio antenna wire has unplugged between the antenna and the connection into the cab. I have all the parts to replace the antenna. How do I get access inside? Do I pull the plastic trim off the front right wheel?
matiebelle is offline   Reply With Quote
Old 10-05-2001, 09:15 AM   #2
PrimeSuspect
I WAS GOING TO REPLACE MY ANTENNA ON A 90 CHEROKEE LIMITED, SO, I LOOKED AT THE WAY THE ANTENNA IS CRAMPED INTO THE FENDER AND THE ONLY THING I CAME UP WITH WAS TO TAKE THE FENDER DOWN - HENCE, STILL USING THE OLD ANTENNA AT HALF MAST.
PrimeSuspect is offline   Reply With Quote
Old 05-18-2002, 08:49 PM   #3
JohnR
Check inside the cab on the passenger side, behind front kick panel. My 88XJ has a two (2) piece antenna cable and the OTHER connection (the one that came apart) is behind this kick panel. I reconnected the two halves and then used electricians tape to hold the two halves together. Radio reception is now GREAT!!!
JohnR is offline   Reply With Quote
Glock Forum
