Radiator Transmission line fitting size - JeepForum.com
post #1 of 8 Old 09-26-2007, 08:38 PM Thread Starter
DMacabre
Anybody know the size of the transmission line where it goes into the radiator? I haven't had any luck searching so far.
88 MJ: some assembly required
98 XJ 2dr: little lift, lotta skidplate
DMacabre is offline
post #2 of 8 Old 09-26-2007, 08:57 PM
tangofox007
3/8.
tangofox007 is offline
post #3 of 8 Old 09-26-2007, 09:25 PM
84j4000
what he said ^^^^
and the top fitting is 3/4", bottom is quick disconnect on my 97
84j4000 is offline
post #4 of 8 Old 09-26-2007, 09:43 PM
JeepRide
JeepRide's Avatar
5/16 i believe
98 xj 4.0L 231 / aw4 /8.25/3.55
31x10.50 a/t 3 inch bastard lift
JeepRide is offline
post #5 of 8 Old 09-27-2007, 03:40 AM Thread Starter
DMacabre
npt? compression thread?
i guess i should have said i wanted to know fitting size and thread type
DMacabre is offline
post #6 of 8 Old 09-27-2007, 09:08 AM
tangofox007
Originally Posted by JeepRide
5/16 i believe
You believe that the oil cooler lines on a 1988 Jeep Cherokee are 5/16? What would be the basis for this feeling?
post #7 of 8 Old 09-27-2007, 09:10 AM
tangofox007
If it helps any, the upper line at the radiator is Gates part #A61117. Rockauto sells it for $3.94.
post #8 of 8 Old 09-27-2007, 02:04 PM Thread Starter
DMacabre
That works.
3/8" Inverted Flare on the female end.
DMacabre is offline
Lower transmission line removal from radiator-2000 jeepjunky22 XJ Cherokee Technical Forum 18 09-22-2012 01:33 PM
Transmission Line Fitting Delano XJ Cherokee Technical Forum 1 07-10-2009 10:55 AM
fitting on lower radiator dirt4900 XJ Cherokee Technical Forum 4 05-18-2009 08:17 PM
Wrench size for rear brake line fitting? jeepercreeperXJ XJ Cherokee Technical Forum 9 02-08-2007 04:14 PM
Lower Radiator Fitting Islandroaddie96 XJ Cherokee Technical Forum 3 03-10-2005 08:13 AM
