radiator tranny hose quick disconnect - JeepForum.com
post #1 of 15 Old 10-19-2005, 09:08 PM Thread Starter
rockodilered
I'm replacing the stock radiator on my '91 XJ Laredo (4.0 I6 automatic w/ air conditioning) with an aftermarket 3-row. How do I get the lower tranny cooling hose off? It's got this "quick disconnect" but this is my first time doing this sort of thing and I don't know how to get the thing off.
rockodilered is offline
post #2 of 15 Old 10-19-2005, 09:15 PM
Dave41079
Dave41079's Avatar
Squeeze the two tabs with a pair of pliers, push towards the radiator, then tug off. It took me a couple of tries to get it right. Putting it back on you just push it on until it clicks and make sure both tabs are all the way out.
1996 Red/Grey 4-dr
4.0/AW4/NP231/D30/8.25
2" Rusty's BB(Spacer and AAL)
Cragar Soft 8's/31x10.50x15 BFG AT KO's
Dave41079 is offline
post #3 of 15 Old 10-19-2005, 09:23 PM Thread Starter
rockodilered
do I need to worry about tranny fluid leaking all over the place?
post #4 of 15 Old 10-19-2005, 09:25 PM
Dave41079
Dave41079's Avatar
I just did this a week and a half ago. When I did it, my Jeep was completely cool..had been sitting all night. I had a drip or two, and that's it...it wasn't even the size of a dime. if it's warm, not sure.
1996 Red/Grey 4-dr
post #5 of 15 Old 10-19-2005, 10:01 PM Thread Starter
rockodilered
I figure this thing should work like the quick disconnect on my air compressor hose, but since I can't squeeze the thing by hand I tried using my channel lock pliers to squeeze the metal part crimped to the hose together with the female end of this connector (see picture) but the thing won't budge. Any suggestions?
post #6 of 15 Old 10-19-2005, 10:07 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
You have to remove the female part to screw into your new rad right? If so, just unbolt it from the rad now and pull the end off once it's out.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #7 of 15 Old 10-19-2005, 10:13 PM Thread Starter
rockodilered
the bottom return tube coming out of the radiator (the male part that goes into the quick disconnect) is already attached to the new radiator, and it doesn't look like you can unscrew it from the old radiator without taking the tube off.
Maybe you're thinking of the compression fitting from the top tranny tube?
post #8 of 15 Old 10-19-2005, 10:23 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Maybe, it's been like 3yrs sinse I did mine. Maybe try to get a wide Zip tie over the plastic clamp and squeeze it tight.
93 Sport
Specs in Profile.
balloo93 is offline
post #9 of 15 Old 10-20-2005, 12:49 PM Thread Starter
rockodilered
After talking to several auto pats stores, including a Jeep parts store, everyone says I need a special tool to get this quick disconnect off. The Jeep parts store said I could get it off without a tool but it would break in the process and I would need to replace it.
My girlfriend's 2000 Cherokee has the same exact connection as my '91 so I'm sure someone has run across this before. Here's a link to the photo again:
Thanks for all your help folks!
post #10 of 15 Old 10-20-2005, 12:54 PM
gregmondro
gregmondro's Avatar
you shouldn't need a special tool. You might just need to take off the lower radiator hose if it's anything like my ZJ was. The lower radiator hose was in the way just enough where I couldn't fully get around the quick disconnects to squeeze them well enough for the thing to pull off.
It is just a quick disconnect like everyone said, you just need to squeeze the two and pull. Sounds easier then it is in some cases though
- NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
gregmondro is offline
post #11 of 15 Old 10-20-2005, 02:31 PM
ChadsXJ
1995 XJ Cherokee
I had to remove that when I changed radiators probably 4 or 5 years ago on an '87 if I remember right, there is a plastic piece that is used as part of the quick disconnect, be carefull not to rip it apart, I think I had to get a new one when I did this.
Not to hyjack, but...Has anyone had a leak that originated from this connection? I think thats where one of my many are coming from.
1995 White XJ 2-Door Sport 145K miles
4.0 6L, 4.5" RC full leaf pack, coils, and fixed length LCAs, IRO Rear BPEs, Front YJ Brakelines, IRO HnT SYE with Front DS, Cragar Blk D-Window 15x8 4"bs, General Grabber AT2s 33x12.50, Rear Hitch with Warn D-Ring Shackle, Dynomax Super Turbo, HD Offroad Shackle Relocation brackets, IRO Front Hooks, Fenders Trimmed, Stock Flares relocated, floor pans replaced.
ChadsXJ is offline
post #12 of 15 Old 10-21-2005, 10:46 AM Thread Starter
rockodilered
Lightbulb
I figured it out. It takes a brake line / tranny line removal tool. See link: removal tool
I got a generic 2-in-1 tool for $9 at carquest and I had the tranny line off in 5 seconds.
Thanks for all your comments. I hope this helps someone in my situation in the future!
'91 Cherokee Laredo
4.0 I6 Automatic
post #13 of 15 Old 10-21-2005, 11:50 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
I just used my fingers.
I've had mine off of my radiator a few times and the ones off of the fuel rail a few times and none of them leak. You just need to be careful with the tabs when you squeeze them.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #14 of 15 Old 10-21-2005, 03:58 PM
JJXJ
I was just going to post about that same exact line. Anybody know how to fix a leaky quick disconnect? Anybody eliminate the fitting all togeather?
Thanks y'all!
1997 XJ Sport-Dark Blue-4.0-AW4-NP 231-235/75R15 Delta Mud Tracs-ConFerr Roof Rack w/4 Baja's up front and 2 Optronics fogs for back up lights-Dynomax Catback-Banks header!-Bulldog remote starter-Sony Atrac3 Deck-10" 200 watt Bazooka
JJXJ is offline
post #15 of 15 Old 10-21-2005, 05:43 PM
Steelghost
Steelghost's Avatar
I guess I got lucky mine came off first try using a pair of needle nose pliers. I dont know why they didnt make the bottom trans line threaded like the top.
Probably because that would be too easy....
Steelghost is offline
Radiator Barn Quick Disconnect Easy Gibson XJ Cherokee Technical Forum 10 12-13-2009 07:35 PM
Radiator Spout where hose connects to radiator overflow bottle.. gregmondro XJ Cherokee Technical Forum 2 08-13-2009 08:49 PM
Tranny fluid radiator hose keeps blowing off? DeepJeep XJ Cherokee Technical Forum 4 01-15-2009 08:36 PM
need quick help with RE gen2 quick disconnect install BigOrangeXJ XJ Cherokee Technical Forum 6 02-22-2007 02:45 PM
Tranny oil cooler quick disconnect - 1989 XJ wreckhog XJ Cherokee Technical Forum 2 06-21-2006 05:34 AM
