I'm trying to fix a vibration and in the process I have temporarily removed my front driveshaft and replaced the rear u-joints with Spicer 5-1310X sealed joints.
While checking the run out of the rear driveshaft I noticed that there is 0.015" of radial movement at the rear transfer case slip yoke. I have recently replaced the rear output bearing, bronze bushing and seal in the extension housing of the NP242 trying to eliminate this play.
Measurement location
I believe this play is in the splines of either the transfer case mainshaft or the driveshaft yoke. Are these pieces commonly replaced together, similar to roller chain and sprockets being replaced together?
