quick xj rear axel swap question - Page 2 - JeepForum.com
post #16 of 20 Old 07-04-2013, 04:24 PM Thread Starter
rubicon17
same here, abs is overrated, I just want to make sure the lines and driveshaft are the same.
rubicon17 is offline
post #17 of 20 Old 07-05-2013, 04:27 PM Thread Starter
rubicon17
someones gota have done this before, anyone? will the brake lines and my 98 driveshaft work? just leave abs wires hanging and pull fuze?
post #18 of 20 Old 07-05-2013, 06:56 PM
austin6137
1990 XJ Cherokee
d35 is a d35 only difference is c clips and abs, driveshaft is the same length and brake line should mount the same
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #19 of 20 Old 07-08-2013, 06:18 AM
Jamie57
If it's got ribbed brake drums and they are 10" then it's not a D35 but a D44.
For free? Grab it and yes it will work and if you really have your heart set on ABS you can swap the tone rings onto the axles and drill the backing plate for the sensor. I think the drive shaft from a D35 to D44 are the same
Jamie57 is offline
post #20 of 20 Old 07-08-2013, 06:22 AM
RockRodHooligan
RockRodHooligan's Avatar
Not nessisarily, I've seen several d35s with the 10" drums out at the JYs
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
