quick xj rear axel swap question - JeepForum.com
post #1 of 20 Old 07-01-2013, 12:24 AM Thread Starter
rubicon17
will a older d35 xj axle with the ribbed drums work on a 98? both have same gear ratio. the 98 has a bad bearing and i can get the other axel for free so figured id just swap it.
Selling 100% Kona & Jbm coffee, heat sealed 1lb 25$
rubicon17 is offline
post #2 of 20 Old 07-01-2013, 11:28 AM
CitadelXJ
Yes. And real axle swaps are very easy and straightforward.
CitadelXJ is offline
post #3 of 20 Old 07-01-2013, 11:51 AM
pokeyxj
Older d35's (86-89?) are not c clip axles. Not that it is any stronger. just won't lose the shaft if it breaks.
2000 XJ Limited, 4.5 Rusty's All spring lift; 265/75/16 BFG KM2's; 4.0, aw4, 242.
2001 XJ Sport, 4.5 Rusty's lift, 32x1150x15 Hankook Dynapro MT's. 4.0, aw4, 231, 8.25 rear with power trax locker.
08 f 150 2.5 lift, 33's, arb.
pokeyxj is offline
post #4 of 20 Old 07-01-2013, 03:13 PM Thread Starter
rubicon17
ok cool, im not sure what year its from but its got the large ribbed drums and my 98 has the smooth drums, the brake shoes are about 1.75" wide, are they the 10" shoes?
post #5 of 20 Old 07-01-2013, 04:54 PM
RockRodHooligan
RockRodHooligan's Avatar
Yes
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #6 of 20 Old 07-01-2013, 05:08 PM Thread Starter
rubicon17
ok
post #7 of 20 Old 07-02-2013, 09:59 AM
austin6137
1990 XJ Cherokee
Assuming you have the c8.25, putting the d35 in is retarded regardless if it was free. Depending what bearing went in your 8.25 it might be easier to fix it then swap it out, like a wheel bearing.
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #8 of 20 Old 07-02-2013, 10:15 AM Thread Starter
rubicon17
post #9 of 20 Old 07-03-2013, 10:06 AM Thread Starter
rubicon17
the older axle doesnt have abs, can i still use it and just pull the abs relay to make the light go out? everything hooks up the same right?
post #10 of 20 Old 07-03-2013, 06:04 PM Thread Starter
rubicon17
anyone?
post #11 of 20 Old 07-03-2013, 09:23 PM
bobbo_xj
I would think the year of the older d35 axle is needed for an answer. -although not from me. You might also need to check rear driveshaft compatibility too. It would be worth knowing the condition of the donor axle, including any whining it may of been making? lol
2001 XJ Sport, 173k mi.
bobbo_xj is offline
post #12 of 20 Old 07-03-2013, 09:34 PM Thread Starter
rubicon17
wow
post #13 of 20 Old 07-03-2013, 09:36 PM Thread Starter
rubicon17
anyone know if this axle can be used?
post #14 of 20 Old 07-04-2013, 11:14 AM Thread Starter
rubicon17
bump
post #15 of 20 Old 07-04-2013, 04:17 PM
austin6137
1990 XJ Cherokee
It should work besides xjs abs is pretty much useless from what I read
