-   -   Quick question on steering (http://www.jeepforum.com/forum/f11/quick-question-steering-1982426/)
JBlue 01-10-2014 05:22 PM
2000xj, 4.0 auto, 112k miles. I bought the jeep 6 months ago and I've had a lot of problems. Doing a bunch of work this weekend to it.
Quick question, how do you fix a steering wheel that has a lot of "give"? There's a lot of play in the wheel. I searched and I kept getting death wobble but mine is at all speeds. No wobble, just a lot of give in the wheel. Thanks as always.
ECL 01-10-2014 08:34 PM
Start by jacking up each front tire and trying to turn it left and right. Look for play in the tie rods, center link, etc.
Your steering box is "young" at 112k but if everything else checks out, you can tighten down the lash on the steering box by loosening the lock nut on top and turning the screw in a little more.
JBlue 01-10-2014 08:41 PM
Perfect, thank you ECL, I will get on that tomorrow. I couldn't find anything on this.
ECL 01-10-2014 08:46 PM
My money is on the rod coming down from steering box. Replacing that on mine tightened up my front a lot.
JBlue 01-21-2014 10:31 AM
Well I jacked up the front of the xj and pulled on the wheels, everything appeared to be pretty tight without much give anywhere. Also, when in park and with the jeep off, the wheel has almost a quarter turn of give in it. So would this be a bad steering box? Would getting an alignment help troubleshoot this?
skyway0018746 01-21-2014 10:45 AM
Sounds like the box is worn out I would suggest a new one rather then adjusting it as there is a fine line between good and locking up the gear which can cause it to seas at any time which isnt good when your driving.
XJaySC 01-21-2014 10:47 AM
If you have that much play in the wheel in park and off an alignment won't help. Probably steering box or intermediate steering shaft play. With a quarter turn I'd say most likely the box.
If you were to tighten it as suggested do it a little at a time. I've heard tightening too much can damage the gear box.
JBlue 01-21-2014 11:14 AM
Thanks jay/skyway. I'll replace the box then.
JBlue 01-28-2014 01:20 PM
I'm going to save up to replace my steering box when I replace my whiny ps pump, service my cooling system, and fix my front main seal. That's going to be a heck of a weekend in the spring, just too cold and expensive now.
Quick question, is it worth getting an alignment now? I'm having a new tire put on my spare wheel before ice fishing up in the adirondacks and the tire place is having an alignment deal. is it worth doing the alignment if I'm going to change the steering box in 3 months anyways or one won't affect the other? I'm clueless in this area. Thanks for any help. Also if anyone had more input into my steering issue it's much appreciated.
ECL 01-28-2014 01:29 PM
If you don't trust your alignment, get it done now. That will ensure that the toe-in/out of the tires relative to each other is correct. When you change the steering box, you won't actually change the alignment of tires relative to each other. You'll only change the orientation of the steering wheel to the tires. That you can adjust yourself by "winding" or "unwinding" the the adjuster on the center link right by the steering box.
JBlue 01-28-2014 01:51 PM
Thanks ECL, this stuff is all new to me. I'm hoping it's the steering box that is going when I replace it in a few months.
Kalali 01-28-2014 06:34 PM
I'm sure it depends on a lot of factors but 112000 miles seems too low for a steering box to go that bad. Are you saying that it takes more than a 1/4 turn before the steering responds to the input?
JBlue 01-28-2014 07:40 PM
Exactly, it's very loose. I jacked up the front and pulled on the wheels and nothing appeared loose, front bearings and shocks are new, tires have 2k miles on them, u joint are tight, mounts look ok. When driving or in park I can turn the wheel about a quarter of the way without much movement. I don't know how to diagnose further. Perhaps the people doing the alignment will pick up on something? If not, I'm going to throw a new box in there when I can afford to unless anyone can think of anything else. I'd appreciate any help/ideas.
skyway0018746 01-28-2014 07:44 PM
Have you checked your track bar ? Specifically the 1/2 " bolt that attaches it to the axle. It can wollow out and cause steering play and possibly death wobble. Also steering shaft u-joints. ( theres another name for them )
JBlue 01-28-2014 08:25 PM
Thanks ill give that a looksie this weekend.
The time now is 03:07 PM.
