Quick question on overheat/cutoff - JeepForum.com
post #1 of 1 Old 01-17-2012, 11:41 AM Thread Starter
spidersfan351
1997 XJ Cherokee
Guys - I just walked a mile back to my office after a lunchtime excursion gone wrong. Bottomed out my XJ in a sandy/muddy gulley, had to spin pretty hard backwards to get out.
(It's a 1997 4.0L 4x4 XJ 5 spd)
Didn't think there was a problem, until 12 miles further down the highway, when I went to get off our main road, the engine just cut off! (I think I had popped it into neutral, but cannot recall for sure).
I noticed the temp was just a notch hot after 8 miles or so, so I was keeping a very close eye one it. After I had backed out of the gulley, I noticed some white smoke but assumed it was some of the water from the small creek evaporating. I would have taken the temp gauge more seriously, but again, it was just one "notch" hot - not significantly different than usual.
I had just topped off coolant at the filler cap three days ago, so I know I had plenty. Under the hood, there appears to be a lot of water (or it could be fluid) on the drivers side, front, around where the air filter. I opened this, and as best I can tell the airflow mechanisms are bone dry inside, so I don't think I got any water up there. Steam/smoke is coming off the top of the engine block.
Bottom line - oil looks fine, coolant reservoir is good - but temp gauge was all the way to hot and motor off. My concern is whether I seize my engine. Could this be possible? There is no way it ran all the way at hot for more than 30 or 45 seconds, as I was paying close attention the whole way and never saw it.
It just concerns me that the motor cut off. Any wisdom on this would be deeply appreciated.
Joe
spidersfan351 is offline
4.0l , cooling system , overheat , xj
another overheat question.. okctsguy XJ Cherokee Technical Forum 4 06-24-2010 05:38 PM
Fuel Cutoff 98GooseXJ14 XJ Cherokee Technical Forum 6 12-09-2009 10:01 AM
fuel cutoff switch. how to? xjcowboy01 XJ Cherokee Technical Forum 6 03-25-2008 04:01 PM
Overheat and A/C question!! HELP osudelt69 XJ Cherokee Technical Forum 7 04-09-2005 08:16 AM
fan motor, and overheat question shawn744 XJ Cherokee Technical Forum 7 10-15-2004 05:28 PM
