Quick fuel question regarding Furl Return Line - JeepForum.com
post #1 of 6 Old 08-15-2013, 05:07 PM Thread Starter
JeepJohn92
1988 XJ Cherokee
So my Fuel Return line, south end of the bay (closest to radiator on the pressure regulator) is leaking a little fuel. I just replaced my fuel injectors and its leaking a little fuel. Causing hard starts along with a Distributor cap that needs replacing. Anyway, does this line require a seal? It wasnt leaking fuel before I removed it and I was pretty gentle with it to not brake that plastic hook on there. Its not a gratuitous amount of fuel but something I will/need to fix.
Colorado Jeep Club Member #343
Built not bought.
JeepJohn92 is offline
post #2 of 6 Old 08-15-2013, 07:47 PM
79chiefs
1988 XJ Cherokee
I think it has an o-ring. Did you make sure the surface was clean before putting the line back on?
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #3 of 6 Old 08-15-2013, 09:38 PM Thread Starter
JeepJohn92
1988 XJ Cherokee
If it has an o-ring thats not an issue. I have an abundance of extra fuel rated ones. And no... I did not. I was in a hurry and I know that is a terrible excuse to be sloppy.
Built not bought.
post #4 of 6 Old 08-16-2013, 04:44 AM
79chiefs
1988 XJ Cherokee
Easy fix, pop it off, if gunk has it leaking clean it, and double check the o-ring.
95 E34 540i-DD
79chiefs is offline
post #5 of 6 Old 08-16-2013, 06:18 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Fuel disconnects
Quick disconnect part numbers
So far the Napa part numbers for just orings is:
Napa 730-5018 3/8 Viton individual orings $1.56 each
Napa 730-5017 5/16 Viton individual orings $1.35 each
Napa CRB 212305 fuel line repair kit 5/16? $15.93 each
Mopar repair kits:
83502745 fuel line repair kit 5/16 $6.99 Morris
83504447 fuel line/Trans line repair kit 3/8 $8.99 Morris
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is online now
post #6 of 6 Old 08-16-2013, 12:50 PM Thread Starter
JeepJohn92
1988 XJ Cherokee
Thanks for the info guys, I appreciate it.
Built not bought.
