Quick Fix for Cracked Exhausted Manifold? - JeepForum.com
post #1 of 13 Old 07-25-2004, 06:57 PM Thread Starter
Wahiya
Question Quick Fix for Cracked Exhausted Manifold?
Is there is a quick fix for a cracked exhaust manifold?
Just found the crack on the downpipe.
Can I weld? Should I replace? How about wrapping it muffler tape temporary?
Thanks!
89 Cherokee - Stock - I6- 5 Speed
Wahiya is offline
post #2 of 13 Old 07-25-2004, 07:01 PM
cfkingfish
cfkingfish's Avatar
If it is on the manifold, I consider a weld to be just a temporary solution - it will probably crack again due to the pressure. If it is on the headpipe, you can probably get away with a plug weld. Your best bet on the manifold is to replace with headers, or turn the music up.
Christian
89 XJ 4.0 AW4
K&N 6x9 cone filter setup
Converted to TJ axles - 5-297 U-joints
Optima Red Top
Custom exhaust
www.ishopfaulkner.com
cfkingfish is offline
post #3 of 13 Old 07-25-2004, 07:04 PM Thread Starter
Wahiya
Turn up the music!
Can't stand the smell coming into the cab...
Wahiya is offline
post #4 of 13 Old 07-26-2004, 10:59 AM
denverd0n
A cracked manifold should be replaced. For the short term, in the meantime, you can use JB Weld to close it up.
denverd0n is offline
post #5 of 13 Old 07-26-2004, 11:03 AM
DefaZ
DefaZ's Avatar
I tried JB weld and a couple other muffler-patch cremes, but they all burnt off and smelled like hell.
I ended up just ordering a replacement grade manifold off ebay...
$140 got me the manifold (with lifetime warranty) and gaskets shipped...
If it breaks, I live about 15 miles to the distributor, and will throw it through their window. then yell. then fart and run.
DefaZ is offline
post #6 of 13 Old 07-26-2004, 12:37 PM
isezumi00
isezumi00's Avatar
so wait...are you going to fart and run at the same time, or fart then run?
'91 XJ Laredo
Rustys 3" Coils Frankenleef rears||DT3000 shocks||JKS Quicker DQ
Optima Red Top||Mixin' match 31x10.5x15|| Rusty's HD Trac Bar
isezumi00 is offline
post #7 of 13 Old 07-26-2004, 12:45 PM
MGrobe
Man In Black
MGrobe's Avatar
If the crack is accessible enough, I would weld it. You can then plan for a better fix later after you decide how long this XJ is going to be part of your life. If she is a keeper, then upgrading to a permanent solution via an aftermarket header should give you the best chance of failure proofing. When I replaced my header, it was a pain in the rear to get everything retorqued down. Wouldn't want to do that again if at all avoidable.
Otherwise it would be a shame to invest a lot of time and money into a vehicle that might only be in your possession another year or two.
MGrobe is offline
post #8 of 13 Old 07-26-2004, 02:46 PM
bryes
Summit racing sells heat tape that is made to wrap headers for insulation. It might be a cheap/easy alternative to replacing if the cracks are in a good position.
bryes is offline
post #9 of 13 Old 07-27-2004, 12:40 AM Thread Starter
Wahiya
Thanks everyone for the replies!!!!!
This XJ has truely been a learning experience! LOL
Wahiya is offline
post #10 of 13 Old 07-27-2004, 01:17 AM
JVracer04
JVracer04's Avatar
...*breath*
1997 Jeep Cherokee... 8" Long arm Lift - still waiting to put it on
JVracer04 is offline
post #11 of 13 Old 07-27-2004, 01:19 AM
ZmOz
Why bother? A little crack won't hurt anything. Mine's cracked and I couldn't care less...
ZmOz is offline
post #12 of 13 Old 07-27-2004, 02:29 AM
JVracer04
JVracer04's Avatar
thats not true from what ive heard... a cracked header will cause a loss of back pressure and ive heard these I-6's are dependant on backpressure
yah it will still run fine, but not at its peak, and long term damage (extreme carbon build ups from the exhaust leaking onto your intake manifold) is always fun
post #13 of 13 Old 07-27-2004, 11:49 AM
ZmOz
Unless the crack is HUGE, and big enough to make your jeep sound like a garbage truck, it is NOT a problem at all. The loss of back pressure will be very minimal and that will be GOOD for your engine. Carbon buildup will be almost non existant....
ZmOz is offline
Cracked Manifold. How bad does this look? PUNISHER_VETTE XJ Cherokee Technical Forum 6 10-04-2009 09:31 PM
Cracked Manifold 96xjCountry XJ Cherokee Technical Forum 1 04-10-2008 01:19 PM
Cracked Manifold XJ95mlake XJ Cherokee Technical Forum 6 06-16-2006 12:17 AM
Cracked manifold on '99 4x4 4.0 BENJMNS XJ Cherokee Technical Forum 10 05-22-2006 04:51 PM
cracked manifold blacky_j XJ Cherokee Technical Forum 2 10-10-2005 10:47 AM
