02-08-2008, 08:25 AM
#1
on my 99' i really want to run 37's but have a limited budget.
i plan on running the RE 5.5 short arm suspension with spacers and longer shackles+ ube's. im not into rock crawling just trails and mud. it will be a dd.
how will the D30 hold up, or should i look for a rubicon D44 for the front, i want to try and keep the stock front axle, with some shafts and truss. in the rear im going for a ford 8.8 with the super 8.8 kit. i want to try and run 4.88's any suggestions? keep in mind its a 4.0 auto, i know 4.88 wont be perfect, but it should be better than the 3.07's and 33's i have now. the link to the build is in my sig
02-08-2008, 08:35 AM
#2
37s + D30 = explosion.
Factory Four Link
02-08-2008, 08:40 AM
#3
www.lp.org
Rubi D44s aren't much better than XJ D30s. You might want to look for a real D44.
Derpy Hooves for President in 2012
02-08-2008, 09:01 AM
#4
but im not looking for full width or the headach that comes with custom axles
-94' cherokee sport- 2 door,5.5 inch lift,thule light bar,daylighters,bushwacked,33x12.50 BFG KM2's-sold
-99' cherokee sport-4 door- http://www.jeepforum.com/forum/showthread.php?t=485911
-03' wrangler sahara- 4.5" susp, 1.25 bl/mml, w/35 BFG MT's, Flowmaster super44
02-08-2008, 09:10 AM
#5
then you shouldn't be running 37s
Factory Four Link
02-08-2008, 09:16 AM
#6
www.midcoastjeep.com
Rubi axles use a 44 R&P only, the tubes are exactly the same small dia. as the 30.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
02-08-2008, 09:18 AM
#7
well thats no good then
02-08-2008, 09:20 AM
#8
Vendor
They're not a whole lot better either since the shafts are marginally stronger, if any (where it counts, at the yokes) and they run the same u-joints as late model D30s.
If you're just running trails and mud, a built 30 should be OK as long as you don't get crazy with the skinny pedal. Though if that's all you're going to be running, I'd probably stick to 35s, especially since you said it's still going to be a DD.
Jason West - Jeepin.com | JeepinOutfitters.com
'09 JKUR, RE 3.5", 37" GY MT/R-Ks, Expedition One bumpers, T&T rockers & skids, XRC10 Comp
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
02-08-2008, 09:22 AM
#9
i beleive jason:aka jeepin.com runs 36 irocks on his rig with a dana 30, 37's shouldn't be too much harder copared to the 36's
edit: i thought he might chime in
02-08-2008, 09:24 AM
#10
i'd probly only run the jeep in the summer, and keep my 94 for the winter, what wheeling i do i like the ground clearence of the 37's
02-08-2008, 09:57 AM
#11
nom nom nom
Some chomo shafts with 760 joints would give you a little more peace of mind. I got mine from Alloy USA(along with gears), but I still don't want anything bigger than 35's on my d30.
You may get lucky with 37's but I wouldn't bet on it. A broken axle is not the end of the world, but it sure can be a hassle. All my axle shaft/joint breaks have happened in terrain where working on it is a pain in the butt. They never seem to break on a nice flat firm part of the trail.
On a side note, your 5.5" lift will clear 37's with proper bumpstopping. Your not going to like those short arms with 7"+ of lift.
Good luck
PS-if you decide to go with Alloy USA shafts order them ASAP. Took me 3 months get all 4 of mine due to back order.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
#12
Well a 5.5 lift with spacers and short arms is going to ride so bad. Its going to shake you to death. Going with 37"s you should get the full widths because you center of gravity is going to be high.
I'm forever grateful to Speedycat and RnEmOvr for their generosity
02-08-2008, 10:00 AM
#13
the kit does come with drop brackets, and i can get a pretty good deal on it
02-08-2008, 10:03 AM
#14
Well get the braces for it so they dont rip off. I guess you're talking about the drop brackets like Jason has?
02-08-2008, 10:28 AM
#15
Vendor
Yes. The RE 5.5" kit comes with the braces standard anyway, so he should be good to go there.
