question on driveshaft slip yoke - JeepForum.com
post #1 of 9 Old 02-23-2007, 12:51 PM Thread Starter
joeksjeep
ok heres a pic from this cherokee i was lookin at buyin, and i noticed it had a different type of slip yoke or something, and im not familliar with it cuz my 92 just has a smallseal and the slip yoke going into the tranfercase. and this is froma 96 so could i get some help one what this is exactly , it also seems that the nose, or cone on the transfer is smaller than mine so heres the link
http://i120.photobucket.com/albums/o...driveshatf.jpg
joeksjeep is offline
post #2 of 9 Old 02-23-2007, 01:21 PM
thenoblesock
1948 CJ2A
maybe you had a 242 Tcase, the cases are a bit longer, other than that this is a standary slip yoke. 231 case. looks identical to mine when it was stock
1948 cj 2a "resto-mod" with a buick v6 and a gm truck 4 speed. stock suspension, wheels, tires, brakes, and steering.
1979 cj-5 renegade blue levi edition. powered by an amc 304, rebuild well done by M&D machine shop of Purcellville, VA.
thenoblesock is offline
post #3 of 9 Old 02-23-2007, 01:25 PM Thread Starter
joeksjeep
im gona take a pic of my slip yoke and post it compared to this one
post #4 of 9 Old 02-23-2007, 01:31 PM
XJH-007
XJH-007's Avatar
Your pic is an Auto tranny setup........the seals/yokes are different.
I'm confused...you want to replace the seal on your 92? or swap the whole thing?
Driveshaft lengths will be different...so if you use the newer setup you will also have to use the same D-shaft.
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #5 of 9 Old 02-23-2007, 07:29 PM
tweekedknee
thats the post 96ish tcase and slipyoke. The good thing about that is if your rear shaft drops the tcase still holds the fluid. The bad part is the driveshaft is shorter which give vibes with less lift
'97 XJ (here comes the typical list)
3" rustys full pack, Rock Krawler tracbar, 31x10.5 Kumho kl71, CIK, dynomax super turbo muffler, IPF h4 conversions, silverstar bulbs, hella 530 fogs, olympic 4x4 rock front bumper, tcase drop, bush hacker flares, OEM tow hook brackets with GM hooks
tweekedknee is offline
post #6 of 9 Old 02-24-2007, 09:31 AM Thread Starter
joeksjeep
no that setup is on a 96 that im lookin at buying and i had no idea what the plus' and minus' of that setup where thats all, cuz my 92 is just a slipyoke with a small seal
post #7 of 9 Old 02-24-2007, 09:34 AM
330LICIOUS
mine is (was) the same, i have a 2000 automatic and 231.
2000 XJ Sport Blue
4.56 HP30/8.25 | AA SYE + CV | ORO U-Turn Steering | RE Extreme Duty Track Bar | TNT Long Arms | 5.5" RE/Bilstein 5125 | 33x12.5 BFG M/T | ProComp Alloy | JCR Sliders | Detours Slimline Bumper/Carrier | ARB Bull bar + Warn M8000
330LICIOUS is offline
post #8 of 9 Old 02-24-2007, 10:43 AM
TMCXJ
Go for it. But be careful when you test drive it, that "rattle noise" might just be the exhaust clamp u-bolt at the muffler/cat that's not exactly all together in the pic you linked.
"...a long habit of not thinking a thing wrong, gives it a superficial appearance of being right, and raises at first a formidable outcry in defense of custom. But tumult soon subsides. Time makes more converts than reason." Thomas Paine
TMCXJ is offline
post #9 of 9 Old 02-24-2007, 03:18 PM
jharte
Yeah, just like my '98 XJ. NP231. I have 4" of lift and it did vibrate quite a bit. With the SYE, no vibes.
jharte is offline
CV slip-yoke driveshaft? XJdesertrider XJ Cherokee Technical Forum 1 08-11-2009 11:43 AM
Slip yoke question carguy489 XJ Cherokee Technical Forum 8 11-20-2008 12:26 PM
Slip yoke elminator Question jpoe XJ Cherokee Technical Forum 4 03-24-2008 01:27 PM
Slip yoke question kafer1963 XJ Cherokee Technical Forum 1 11-25-2007 09:41 PM
Question about Slip Yoke. Jerka XJ Cherokee Technical Forum 1 08-22-2006 08:24 PM
