Question about TSB's.... - JeepForum.com
post #1 of 7 Old 01-03-2007, 07:57 AM Thread Starter
dubaudi
Does anyone know if a dealer will honor a TSB if I'm the second owner of the car and it's out of warranty? I'm just wondering because I did some research and found that there are a bunch of TSB's out there that would seem to perfectly describe some minor issues I have with my '00 XJ.
I'm wondering if I can go have them done, or if I'll need to pay? Does anyone have experience with this, or maybe work at a dealership and know the answer?
Thanks!
dubaudi is offline
post #2 of 7 Old 01-03-2007, 08:19 AM
Ben
I'm the 4th or 5th owner of mine, I just got the free cat from a TSB...
you should be fine if you take it to them and specify that you only want recall/no-charge work done
Ben is offline
post #3 of 7 Old 01-03-2007, 08:41 AM
anony91xj
The free cat was a recall.
A TSB is a Technical Service Bulletin. They're simply a list of common problems put out by the manufacturer to help technicians diagnose and repair problems. That's all they are. Pick any car, any make or model, and you'll find a mile-long list of TSB's.
TSB's are not recalls, and no one will fix them for free.
1998 VW GTI 2.0
anony91xj is offline
post #4 of 7 Old 01-03-2007, 09:06 AM Thread Starter
dubaudi
I thought I read on here somewhere of a few people that had, for example, the infamous TC linkage rattle and the hot-start-rough-idle issue repaired by dealers at no charge because they were TSB's.
Not that I'm questioning what you're saying, I'm just wondering if maybe someone that works at a dealer is here and can give a definitive answer.
dubaudi is offline
post #5 of 7 Old 01-03-2007, 09:15 AM
cmotsvt
TSB's are not recalls. If you had a good relationship with a dealer they might fix items in a TSB but they wouldnt be obligated to unless it was under a bumper to bumper waranty. Even under a warranty you sometimes have to twist their arms.
cmotsvt is offline
post #6 of 7 Old 01-03-2007, 09:23 AM
Ben
... my bad
Ben is offline
post #7 of 7 Old 01-03-2007, 09:27 AM
QHays
Just got the Stealership to flash the PCM as per a recent TSB. Cost $85 because it wasn't a recall...
QHays is offline
Rear swaybar question and e-brake question callmebobbyt XJ Cherokee Technical Forum 13 05-16-2008 11:52 AM
Airbag question and a distributor modification question! (i searched) Jameslol XJ Cherokee Technical Forum 2 05-11-2008 02:08 PM
TSB's for 2001 Cherokee Sport??? Where to Find on the WEB weebs74 XJ Cherokee Technical Forum 1 11-17-2005 08:02 PM
86-92 TSB's for 2WD AND 4WD 6CYLINDER ENGINES balloo93 MJ Comanche Technical Forum 0 06-25-2005 11:24 PM
Power window question or electrical connection strengthener question daveleau XJ Cherokee Technical Forum 1 08-07-2003 08:14 PM
