Question about Lifts & Vibrations 2WD - JeepForum.com
post #1 of 6 Old 03-13-2011, 07:02 PM Thread Starter
fedx95
1993 XJ Cherokee
I got a 2WD cherokee. If I were to do a 4"lift, would I get vibes, even though I don't have a transfer case? I know theres a lot of material on this subject, but its mostly people with the 4wd, which doesn't apply in this situation.
Its a 96 XJ, and my rear leafs are sagging
I plan on duplicating this lift setup
http://www.jeepforum.com/forum/f11/add-4-145-a-1108267/
(thanks ratjaw)
fedx95 is offline
post #2 of 6 Old 03-13-2011, 07:04 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
With the longer rear drive shaft, I think you will be fine. If not just shim the rear axle to line up correctly.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 6 Old 03-13-2011, 07:05 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You should be fine with 4"of lift on the 2wd. You have a longer driveshaft which means less angle after the lift. I cannot confirm this, just an expectation. I have a 95 4wd with 4" of lift and have very minor vibrations. I am installing the t-case drop I built today in the morning to get rid of mine.
xjfever is offline
post #4 of 6 Old 03-13-2011, 07:09 PM
GregB_00XJ
Hey man...
The easy answer, you might. The older Cherokee's are supposedly less likely to get driveline vibrations after a lift, but it is still possible if your driveline angles (rear pinion) are not correct and you get binding. In your case I do not know what options there are? Shims and a custom DS?
I honestly have never seen a 2WD Cherokee from underneath, and so my comments are speculative at best. I am certain someone more educated and versed in the 2WD Cherokee can answer better than I can.
At 4" you might get lucky and have no issues whatsoever?
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #5 of 6 Old 03-14-2011, 01:30 PM Thread Starter
fedx95
1993 XJ Cherokee
so far sounds good then, I want to do a BB but having to mess with vibrations drives the $ up. I see what you mean, b/c my driveshaft is definitely longer by about a foot. When I do the lift I'll post about it
fedx95 is offline
post #6 of 6 Old 03-17-2011, 06:42 PM Thread Starter
fedx95
1993 XJ Cherokee
well, i definitely have to replace my rear shocks and springs. I went to an abandoned lot that was all gravel, and I was bottoming out a lot. My rear end is sagging like 2 inches below the front.
fedx95 is offline
2wd , cherokee , lift , vibes , vibrations
Question about lifts smitty81 XJ Cherokee Technical Forum 18 03-04-2011 08:35 AM
Just a question about 2 lifts. heathcliff1962 XJ Cherokee Technical Forum 3 01-18-2008 07:37 PM
Question about RE lifts Rasalibra XJ Cherokee Technical Forum 2 12-20-2006 09:04 PM
Lift Opinions and Vibrations Question XJ2000 XJ Cherokee Technical Forum 17 12-01-2006 09:11 AM
question about lifts.. kaytoos XJ Cherokee Technical Forum 15 02-21-2005 07:58 PM
