Question about CV Driveshaft or Make my own - JeepForum.com
post #1 of 12 Old 01-11-2009, 09:44 AM Thread Starter
Hella
Okay simple question is it better to buy the CV driveshaft or can I use the front xj one with the spicer part to use with the SYE ill most likely have to get?
Hella is offline
post #2 of 12 Old 01-11-2009, 09:56 AM
crumb
what are the details of your cherokee?
My
1999 Cherokee Sport
4.5" RE Superflex Lift
crumb is offline
post #3 of 12 Old 01-11-2009, 10:58 AM Thread Starter
Hella
Stock 2000, I6, Auto, NP242 and about to purchase a RE 4.5 SF kit with 31x10.50 tires and im sure i will need a sye but i will have to wait for more money and looking for a cheaper route than a new shaft.
Hella is offline
post #4 of 12 Old 01-11-2009, 11:03 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Better is not the point. The whole idea is that the stock front drive shaft works perfectly and is cheap. Another benefit is that you only have to carry one spare driveshaft to fit front or rear. The used one may need new u-joints and a new centering ball or you might get lucky and find a good one with low miles.
CJ7-Tim is offline
post #5 of 12 Old 01-11-2009, 11:18 AM
99Greenmachine
How do you know if you need new U-joints and/or a new centering ball? Is there a test/inspection process?
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
post #6 of 12 Old 01-11-2009, 11:36 AM
CJ7-Tim
CJ7-Tim's Avatar
You can check the u-joints to see if they are too tight or too loose. The centering ball makes a squeaking/chirping noise when it goes out. I always put new u-joints in junkyard drive shafts, that way you are sure they are good.
CJ7-Tim is offline
post #7 of 12 Old 01-11-2009, 11:46 AM
rob92xj
1992 XJ Cherokee
I have about 20000 miles on my front shaft being used in the rear and have no problems at all. Installed new U-joints the shaft came out of a 99 XJ and the centering joint was good.
rob92xj is offline
post #8 of 12 Old 01-11-2009, 12:23 PM Thread Starter
Hella
so for my situation it would be a good idea to head up to a junkyard and pull a front driveshaft off of an xj and use that? Also all the XJ's with the D35 used the same driveshaft?
Hella is offline
post #9 of 12 Old 01-11-2009, 12:49 PM
RockRodHooligan
RockRodHooligan's Avatar
With the NP242, isn't your only option for a SYE a Hack-n-tap? If thats the case, isn't the RE HnT(flange type) your only option(though I have heard Tom Woods has a yoke type HnT, but can't find it on the web site)? In the case of the RE kit, you have to get a flange adapter from Spicer(part # 211229x), that requires removing both cardan u-joints, and comes with a new centering ball. I replaced all the u-joints while building mine, since 2 of the 3 u-joints were out already.
89 and up automatic XJ's have the drive shaft you probably want, although I have fount that MJ's(Comanche) had a slightly longer shaft(about an inch).
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #10 of 12 Old 01-11-2009, 01:42 PM Thread Starter
Hella
I was planning the Re HnT but I didnt want to have to get a whole new driveshaft built cause that gets expensive. I found the option of getting a xj front and getting that part from spicers.
So im most likely going to pick up a RE HnT, XJ Front Shaft, and a Spicer Part and use that as my SYE.
Hella is offline
post #11 of 12 Old 01-11-2009, 02:11 PM
rob92xj
1992 XJ Cherokee
Tom Woods has/had a SYE for the NP 242 but when I went to order mine they were out of stock and was told they didn't know when to expect them as people were not sending there old mainshafts back to them. I did install one on a friends ZJ and it was like any normal SYE.
I ended up with a RE hack and tap with the Spicer flange part number 211229x and a front XJ shaft I have not had any problem yet and it has been installed since 07
rob92xj is offline
post #12 of 12 Old 01-11-2009, 03:51 PM
RockRodHooligan
Best price if found for the flange adaptor hands down!
http://www.alljeep.com/oscommerce/ad..._description=1
When I rebuilt mine I think I spent $100 on the shaft all said and done, $10 JY shaft, $45 flange adaptor, $45 3 new u-joints
96 XJ:
***** inches...
doorless in an 87? how to make it easy is the question? wojtizzlator XJ Cherokee Technical Forum 15 06-04-2007 05:04 PM
Question on new driveshaft and sye supes82 XJ Cherokee Technical Forum 2 02-15-2007 09:44 AM
Front Driveshaft as CV Driveshaft Question AustinXJ13 XJ Cherokee Technical Forum 3 01-11-2006 10:02 PM
driveshaft question slayer2000 XJ Cherokee Technical Forum 2 10-28-2005 03:57 AM
driveshaft question silver2000XJ XJ Cherokee Technical Forum 4 10-25-2002 08:04 PM
