Question for 8.25 29 spline with locker - JeepForum.com
post #1 of 3 Old 04-24-2012, 12:15 AM Thread Starter
Terry777
1997 XJ Cherokee
Could use more imput on my 8.25 29 spline, I now it can handle 35 inch tires & I know a guy who ran 35X14.5X15 super swamper thornbirds on a 27 spline and have no issues, with that being said he is not retarded and knows how to drive.
Ok so my question is if I wanted to put in a ARB air locker in would the 8.25 ,29 spline be able to handle 35 inch tires, say no wider than 12.5 & if not how big. This is considering I`m not rock crawling and stomping the skinny pedal.
I have a Blue torch heavy duty diff cover on it now so less flexing of the housing or so I`ve been told.
Thank you in advance for your advise I know this is the site for getting to the bottom of things
Looking for advise from a diff guy or engineer type for me to make a confident decision
Terry777 is offline
post #2 of 3 Old 04-24-2012, 12:23 AM
egodfrey
egodfrey's Avatar
Im not an engineering major, but the 29 spline 8.25 will handle the 35's in my opinion especially with a light foot. You can get aftermarket shafts for fairly cheap as well. And the Arb is a strong full case locker. Ericsxj ran (maybe still does) 35's on his 29 spline 8.25 for quite a while up and down the rubicon trail and had good luck with it.
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #3 of 3 Old 04-24-2012, 10:55 AM
donthelegend
The 29 spline 8.25 is generally considered capable of handling 35s, especially with a full case locker, heavy duty diff cover, etc. After market shafts may also be a good idea if you want a higher margin of safety, but there are plenty of people wheeling 35s on stock shafts.
donthelegend is offline
8.25 29 spline aussie locker on ebay 90xjblue XJ/MJ Cherokee Non-Technical Forum 1 04-23-2012 05:29 PM
Where Can I Find a Lunchbox Locker for a 29 Spline 8.25 Tom95YJ XJ/MJ Cherokee Non-Technical Forum 3 04-16-2012 07:17 AM
Detroit Locker and a 29 Spline XJ caspersflight XJ Cherokee Technical Forum 15 07-15-2011 08:11 PM
locker / spline question Red Raider XJ Cherokee Technical Forum 9 08-03-2009 11:31 AM
Chrysler 8.25 29 spline locker jpg0511 XJ Cherokee Technical Forum 10 03-16-2008 07:39 PM
