Quantcast Quality Replacement OEM Fog Lights - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Quality Replacement OEM Fog Lights
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 12-06-2007, 12:18 PM   #1
Alexia
What are some good replacement OEM fog lights? I keep replacing them with the OEM fog lights and they keep rusting every year. I have to get it done for inspection since it is required to have factory fog lights in good condition.
I am partial to after market replacements as well. Please, I will take any suggestions that save me from spending money replacing these every year.
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Build Project Thread
Rocker Guard Comparison Chart - Final Differential Gear Ratios - Oxygen Sensor FAQ
Alexia is offline   Reply With Quote
Old 12-06-2007, 12:25 PM   #2
tangofox007
How can factory fog lights be required when they were not standard equipment to begin with?
I have some Hella 450's. They are all plastic and glass on the exterior, except for the mounting bracket. Not much to rust.
tangofox007 is offline   Reply With Quote
Old 12-06-2007, 12:37 PM   #3
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
These would be pretty nice:
http://www.piaa.com/Lamps/Lamp-pages/940T.html
My PIAAs are getting close to 20 yrs. old and look like new.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline   Reply With Quote
Old 12-06-2007, 12:51 PM   #4
Alexia
In Pennsylvania, if they came with the vehicle and are part of the head light controls they are required to being in good working condition.(Meaning, the fog lights are factory installed with a factory switch and the high/low beam automatically switches the fog lights as well.) I can completely remove them and that would make them happy, but I want them!
Those PIAA and Hella's do look nice.
Old 12-06-2007, 11:03 PM   #5
iaml3lue
i just got some hella 530s an they wored right up to the factory harness an are abs plastic so they wont rust again they arent making the 530s anymore but they have a new version an they should be around 100 dollars if you want to go cheap look into westins an were in pa is york if your close to jersey i work for a aftermarket store ill hook you up by installing them for free if you want
1998 Jeep Cherokee Classic
4.5"suspension
35x12.50r15
d30/8.25
automatic
iaml3lue is offline   Reply With Quote
Old 12-07-2007, 12:10 AM   #6
XJ2000
Why don't you just remove them for the inspection and then put them back on after? On a smaller level, I do that with the taillight guards on my g/f's Liberty because it's illegal to have them here in Jersey.
North Jersey Jeep Club
Trail Rig: 2000 XJ w/ 4.5" RE SF, Locked XJ D44 Rear, Locked D30, and a bunch of other things
Pavement Pounder: 2001 XJ Daily Driver, 2" BB, 245/70R16 AT's on Moabs
XJ2000 is offline   Reply With Quote
Old 12-07-2007, 06:40 AM   #7
FransWhiteXJ
In NH if aux lights are installed on your vehicle, factory or not, and one or both are not working, you will fail inspection. My wife's Subaru had a broken factory fog light (projector type), which caused a reject. Since they are about $250 each, I went home and removed both of them. Now her car has nice "factory brake cooling scopes".
Fran
PS if you decide to buy Hella's try this site: http://ptcfactoryoutlet.com/ They sell new and repackaged (cheap) Hella products. PTC's sister company, Yellow and Blue is a site sponsor.
FransWhiteXJ is offline   Reply With Quote
Old 12-07-2007, 09:42 AM   #8
Alexia
Fran
Our inspectors tend to be picky around here. *shrugs* I might be able to get away with just taking them off temporarily.
However, those round Hella lights look really nice. *click*
Old 12-07-2007, 10:46 AM   #9
tangofox007
Required to be working is one thing. Required to be installed is another. If I was in a hurry to pass an inspection, an inoperative aux light would become uninstalled in short order.
Old 12-07-2007, 02:25 PM   #10
louisd11
O Rly which store?
2000 XJ Jeep Cherokee Sport 4.0 HO I6
NP231, AW4
-Dana 30 Front w/ 3.55 Gears
-Chrysler 8.25 Rear w/ 3.55 Gears
Horn Blasters 4 Horn set, Dynomax cat back sys., K&N FIPK, Fire Ext., Warrior Bumper (HERCULINEDw/ D-Ring Tabs)
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[ ]llllll[ ]
_.(o)_)__(o)_)--o-)_)
louisd11 is offline   Reply With Quote
Glock Forum
