Putting together 4.5" hybrid lift, have question.. - JeepForum.com
post #1 of 1 Old 11-04-2009, 11:21 AM Thread Starter
xjfan
I've been putting together parts for a 4.5" but thinking of going a little higher.
4.5" question...
If I were to leave it at 4.5", would I need aftermarket or longer fixed upper control arms? At this time I have a set of Rusty's adjustable lower control arms. Wasn't sure if it was needed or not.
5.5" question...
Was thinkikng of using adjustable upper and lower control arm. Going to use a spacer along with shackle but how about this track bar. RE1600. Do you think it could be used at this height? Will I have to go with something else? Was planning on making a double shear bracket, not sure if this would help. Seen other use it but not sure if it give any problems.
Your thoughts, suggestions and opinions always welcome...
Thanks for your help. Hope to one day have this completed..
Joe
1999 XJ Sport, Black on Black, 4.0L
Follow build-up
xjfan is offline
OME Hybrid Lift 06bigdaveJP XJ Cherokee Technical Forum 3 02-10-2009 07:48 PM
?'s about hybrid lift on XJ B-mac XJ Cherokee Technical Forum 6 01-19-2006 02:25 AM
Question about putting my Cherokee on a 2 post lift cherokee_sport XJ Cherokee Technical Forum 5 10-05-2005 07:46 PM
running the DPG/RE hybrid 5" with 36s? can it be done? Magic2979 XJ Cherokee Technical Forum 17 07-07-2005 02:42 PM
putting on 3" have a question GKB XJ Cherokee Technical Forum 1 04-22-2002 12:13 PM
