Putting a Pionerr DEH-1400 CD Deck in a 1996 Cherokee -- help pls. - JeepForum.com
post #1 of 13 Old 07-07-2009, 04:14 PM Thread Starter
hobo13
I've got a Pioneer DEH-1400 CD deck from my old car that I'm working at installing in my 1996 Jeep Cherokee Sport. I've got the wires all spiced together, and it sounds great!
But I don't have the right mounting hardware to actually install it in the bay. I'm guessing I need a 'fit kit'. Can someone suggest which fit kit I need?
Thanks.
hobo13 is offline
post #2 of 13 Old 07-07-2009, 07:06 PM
Fire-XJ
1982 CJ2A
Try crutchfield.com. They list everything you need by vehicle make and model.
Fire-XJ is offline
post #3 of 13 Old 07-07-2009, 07:17 PM
Ac1d
Is it a double bay? I have an 87 and its a single and my pioneer deck fit perfect. Just be sure to install the removable cage before installing the deck. Also make sure to run the wires through the middle of it. The removable cage that came with the deck should have some form of push out tabs, they should bend out to a 90degree angle. Just be sure to bend them after you have inserted the cage into the dash. The tabs should pinch themselfs in between the front lip on the cage and the bezel where the stereo is mounted. Here is a picture of what I'm talking about, the triangle shape cut outs are the tabs I'm talking about. http://www.deals-on-ice.co.uk/shop/i...eo%20cage.jpeg
Ac1d is offline
post #4 of 13 Old 07-07-2009, 07:18 PM
Tarukai
X2 on this.
Crutchfield is the car audio DIYer's best friend. They will list the parts you need when you do their vehicle match.
Tarukai is offline
post #5 of 13 Old 07-07-2009, 07:32 PM
basso4735
basso4735's Avatar
1997 XJ Cherokee
Or just go down to a local car audio place, they will help you out. probably more expensive than crutchfield but no wait
- Includes bastard pack and cheap 3" lift info
Red 97 XJ Sport 5 Speed - Lifted 3" - Sound system - C4X4 Tow Hooks - Hella 500s
Black 96 XJ Classic - Stocker on 31s - SOLD
basso4735 is offline
post #6 of 13 Old 07-08-2009, 10:17 AM Thread Starter
hobo13
It's a single bay. Crutchfield shows this part. I called to confirm, and they say this will do it. It just looks odd to me, but I guess a lot of the extra pieces snap off.
I'll also check-out Car-Toys today and see what they have.
Thanks a lot!
hobo13 is offline
post #7 of 13 Old 07-08-2009, 11:36 AM
Tarukai
You're exactly right. That's an adapter for domestic vehicles, and it has all of the screw mounting tabs, but you break off all of the ones you don't need.
Tarukai is offline
post #8 of 13 Old 07-08-2009, 01:10 PM
justanotherjpr
Yup, it is single DIN. Wal-Mart sells the dash kit you need, made by Scoshe.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #9 of 13 Old 07-08-2009, 02:38 PM
TheNerd
TheNerd's Avatar
I don't know if it is different on a '96, but for my '87, I re-used the mounting bracket from the factory stereo (which also supports the back of the stereo). That thing had holes all over the place, and some of them lined up perfectly with some mounting holes in my stereo...
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline
post #10 of 13 Old 07-08-2009, 02:45 PM Thread Starter
hobo13
This is actually what I did for now. I looked at the 'fit kits', but they all seem to support just the front of the deck. So I used the original mounting bracket with the new deck, and got it attached. The only problem is that there is now a bit of a gap around the opening. Not sure I should care too much though....
hobo13 is offline
post #11 of 13 Old 07-08-2009, 09:51 PM
Ac1d
Do you have the bezel for the deck installed? It should have come with a bezel that goes around the face of the head unit. Typically its in between 1/8" - 1/4", but this all depends on the shape of your head unit.
Ac1d is offline
post #12 of 13 Old 07-09-2009, 08:10 AM
TheNerd
TheNerd's Avatar
Yeah... I've got a little gap around the face plate as well. I have been considering making a thin wooden "bezel" located behind the dash plate (and painting it the same color as the interior...which for me is black) to mask the gap a little more.
...I saw something similar done on Unique Whips once.. BLING BLING!
TheNerd is offline
post #13 of 13 Old 07-09-2009, 03:52 PM
georgiachaos
I put a similar pioneer in my 2000 xj. I used a mounting kit I got from Walmart. It covers the gap and is secure. Not to mention it was cheap.
georgiachaos is offline
1996 Cherokee Tranny???? Vinaard XJ Cherokee Technical Forum 4 01-05-2011 03:50 AM
1987 Cherokee for 1400 yes or no fratboy274 XJ/MJ Cherokee Non-Technical Forum 4 02-04-2010 01:24 PM
1996 Cherokee will not crank parkermms XJ Cherokee Technical Forum 4 05-16-2006 12:21 AM
putting system in 94 cherokee coolgpgt XJ Cherokee Technical Forum 3 07-25-2003 02:15 PM
Help with my 1996 Cherokee Knowklew XJ Cherokee Technical Forum 4 02-27-2003 08:51 PM
