PSC Steering Box - Too Tight? - JeepForum.com
post #1 of 6 Old 09-21-2011, 03:39 PM Thread Starter
Palmetto
Palmetto's Avatar
1981 CJ7
I just had a new PSC steering box put on my 2000 XJ.
I had decent steering wander before, and that is totally gone now.
Now my problem is that the steering wheel is a little harder
to turn, and wherever I point the wheels, is where the steering stays.
Normally, a vehicle will try to track straight and will just readjust somewhat
after turning the wheel. My XJ no longer does that, so I have to make a ton of corrections all the time.
Do y'all have any suggestions? Do I need a stronger steering pump?
ΜΟΛΩΝ ΛΑΒΕ!
Do your duty in all things. You cannot do more, you should never wish to do less.
Robert E. Lee
Groups
Originally Posted by DiabloYJ View Post
It's a Jeep thing, I don't even understand it sometimes.
1981 CJ-7, AMC 360 bored .30 over, Edelbrock Intake, Edelbrock Cam, Edelbrock Double Roller Timing Chain, Holly 650 truck avenger carb, Flowcooler water pump. '97 Dodge 4wd Std NV4500. D300 Twin Sticked. Corbeau Seats, Custom Dash with Autometer guages, Electronic Speedo, all stainless hardware, Outlaw II Wheels, BFG AT 33" Tires, Flex-A-Lite Dual Electric Fan, AGR steering box, Borgeson steering shaft, ididit tilt column, Mean Green Starter, Tuffy console, poly gas tank, handmade rear bumper, cheap radio and speakers.
2000 XJ - HO 4.0L, 245/75R16 Goodyear Wrangler Duratracs. PSC gearbox. IRO Double Shear Trackbar. New headliner. IRO Hack & Tap SYE. IRO adjustable UCA & LCA, RE 3.5" lift, Bilstein 5100 shocks, JKS Quick Disconnects. Future mod: OTK steering, lockers, FIPK, rock sliders, JCR Bumpers, rear storage, high pinion rear (3.55), frame reinforcement, hood louvers, rack lighting.
Palmetto is offline
post #2 of 6 Old 09-21-2011, 04:26 PM
justanotherjpr
Did you bleed the box after installing?
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #3 of 6 Old 09-21-2011, 05:39 PM Thread Starter
Palmetto
Palmetto's Avatar
1981 CJ7
Well, I had it at the shop for a transmission flush, and since I am hard at it rebuilding my CJ, I just took the box to them to let them do it.
I assume they did a good job. They have done great work for me in the past.
Palmetto is offline
post #4 of 6 Old 09-21-2011, 06:09 PM Thread Starter
Palmetto
Palmetto's Avatar
1981 CJ7
From doing more research, looks like I am not the first person to have this problem.
Seems like I may need to adjust the steering box using the adjustment screw on top.
I have this box on my XJ now: SG251 PSC Gear box
This is a great writeup on what I think I need to do: Steering Gear Box Adjustment
Palmetto is offline
post #5 of 6 Old 09-23-2011, 01:19 PM Thread Starter
Palmetto
Palmetto's Avatar
1981 CJ7
I adjusted the screw a little last night. Seemed to help, but not enough. Jeep still won't self-center.
I'll work on it more this weekend.
Palmetto is offline
post #6 of 6 Old 09-24-2011, 09:11 PM Thread Starter
Palmetto
Palmetto's Avatar
1981 CJ7
Loosened the screw a little more. Steering is noticeably better. Tolerable now, but I may tweak it a little more.
I must have not put the fan back in right though, cause when the AC kicks on, I get a vibration in the jeep. I had no time to even lift the hood to troubleshoot tonight (home with a sick little boy). So, hopefully tomorrow.
ΜΟΛΩΝ ΛΑΒΕ!
Robert E. Lee
Groups
Palmetto is offline
tight steering 99xjjoe XJ Cherokee Technical Forum 1 10-01-2009 07:35 PM
Steering very tight ( oversteer ) markcap XJ Cherokee Technical Forum 4 12-28-2007 12:21 AM
tight steering justinwalden XJ Cherokee Technical Forum 3 12-16-2007 06:19 PM
Steering Too Tight louisd11 XJ Cherokee Technical Forum 7 04-24-2007 09:03 AM
jump during tight steering?? Brandon11130 XJ Cherokee Technical Forum 9 09-19-2005 06:43 AM
