Proportioning Valve - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Proportioning Valve
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 05-29-2009, 05:53 AM   #1
joshs1ofakindxj
Proportioning Valve
So I'm putting rear disc brakes on the 89 XJ, and therefore putting in a proportioning valve (PV) from the grand cherokee I got the disc brakes from.
The old PV in my NON-ABS 89 XJ has two connections for the front brakes and 1 connection for the rear brakes.
The PV from the ABS 96 ZJ has 1 connection for the front and 1 connection for the rear. Where the 2nd connection for the front is located there is a threaded plug for something but it does not appear to be a place to connect the other front brake line because it doesn't look like a seat for a double-flared connection.
Correct me if I'm wrong.
So do I need to find a PV from a NON-ABS ZJ with disc brakes?
Can I run one brake line front the PV's single front brake connection and then use a "T"-connector to split the line into the two lines needed for the front? Would that be bypassing something in the ABS unit or non-ABS PV that I'm missing?
Thanks.
joshs1ofakindxj is offline   Reply With Quote
Unread 05-29-2009, 12:33 PM   #2
nostaw22
When I did the conversion I didn't bother changing proportioning valves, and the brakes work fine, so if you do nothing it will be "OK".
I was talking to my mechanic about it and he said there is a spring which helps hold residual pressure, which is different for the drum / disc brakes. He said just pull the spring from the GC proportioning valve rear output line and use it to replace the spring in the XJ proportioning valve's rear output. I haven't done this yet since the brakes don't seem to drag using the stock XJ proportioning valve and I don't have a GC proportioning valve.
Not sure if this helps, but it may save you some hassle.
JW
1998 XJ - built for offroading
2007 WK CRD - DashHawk, for towing the XJ
nostaw22 is offline   Reply With Quote
Unread 05-29-2009, 02:22 PM   #3
AZ Jeff
JW
Your mechanic is correct. Just put the GC spring in the XJ prop. valve.
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Unread 05-29-2009, 06:02 PM   #4
Ed Rico
1997 XJ Cherokee
Thanks.
The ZJ valve will work fine for you. Just remove the threaded plug from the ZJ valve and replace it with the threaded adapter in the same location from the original XJ valve. This will allow you to install all 3 of the XJ lines in the original location if you remount the ZJ valve on the XJ valve bracket. The ZJ valve only has the 2 outputs because it doesn't split the 2 fronts out until after the ABS. I put the ZJ valve on my XJ with the ZJ rear disc conversion and it works fine just as described above. Note that depending on what year ZJ valve you have, you may need to scavenge the electrical connector from the donor vehicle. I still have to do this on my '98 XJ since the switch on the ZJ valve uses a different connector than the original.
-Ed Rico
Ed Rico is offline   Reply With Quote
Unread 05-29-2009, 10:30 PM   #5
alexrule123
I tried that when I did the conversion and didn't notice any difference in brake performance, after putting in the zj prop valve I noticed a huge difference. Also make sure you get the cap that holds the prop valve in the zj master cylinder since the zj one has a smaller internal diameter and will leak fluid when the brakes are applied.
1999 Cherokee Classic: R.I.P. http://www.cardomain.com/ride/2313036
2001 Cherokee Limited My Build Thread: 6" IRO Long Arms and coils, JKS ACOS, IRO 5.5" Leaf Springs, Liquid Iron Industries Slider Boxes, 35x12.50 Goodyear MTR/K, RC Quick Discos, Fox 2.0 IPF Shocks, Rear Disk Brakes, WJ Brakes and steering, JCR Rock Sliders, 60mm Bored TB, Cobra Injectors, Rugged Ridge Header, 2.5" Exhaust with Borla Muffler
alexrule123 is offline   Reply With Quote
