Proper Way to SeaFoam a Jeep - JeepForum.com
post #1 of 5 Old 04-19-2012, 10:41 PM Thread Starter
RyansCherokee89
1989 XJ Cherokee
I've been wanting to run some SeaFoam through my Cherokee and I've been told TONS of ways to do it. But I'm not too sure the the "best" way to do it. I have an 89 Cherokee Laredo. Any help or advice would be great. Thanks.
...It's a Jeep thang...People on here will understand.
RyansCherokee89 is offline
post #2 of 5 Old 04-20-2012, 01:51 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
remove the intake tube and with the jeep running, SLOWLY pour seafoam into the throttle body. if it sputters and nearly dies, pour slower. youll only need about 1/3 can. after you pour it in, let it sit for 5-10 minutes and start it up. should be a nice smoke show. i usually pour the rest into the gas tank
1990JEEPXJ is offline
post #3 of 5 Old 04-20-2012, 05:26 AM
Azzy
pour some of a rag, wipe out the inside of your throttle body. Dump some in your fuel tank. Or not.
The more I read and the more I think about it, I cannot see much need for seafoam over most of your other cleaners. I dont think it will hurt past cooking off mostly in your cats and making a not nice to breath smoke.
One place I would still use it... pouring a bit in your crankcase about 1/2 hour before your next oil change, and go for a drive around the block.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #4 of 5 Old 04-20-2012, 08:14 AM
wsar10
2003 WJ
yeah....
scrap the seafoam and use MMO in the gas and HM oil for the oil.
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #5 of 5 Old 04-20-2012, 02:54 PM
CCKen
CCKen's Avatar
The best way to use Seafoam is to use it to clean the oil spots off your driveway. That's about it. I've used Seafoam and the changes it made it didn't amount to a pinch of $chit.
Use Mopar Combustion Chamber Cleaner if you want to clean your 'combustion chambers'. Get it from your Chrysler dealer.
CCKen is offline
cherokee , sea foam
Seafoam-How do you use it in your Jeep?? smokingun45 XJ Cherokee Technical Forum 42 09-21-2009 08:42 AM
Seafoam Made My Jeep Run Worse?? phmaris XJ Cherokee Technical Forum 32 08-18-2009 08:11 PM
Going To Go And Seafoam My Jeep! Meatroach XJ Cherokee Technical Forum 29 10-02-2006 01:49 PM
video of seafoam in a jeep beavis417 XJ Cherokee Technical Forum 6 08-15-2006 06:19 PM
Seafoam + old jeep cmotsvt XJ Cherokee Technical Forum 3 04-26-2005 10:35 PM
