proper tire pressure - 225/75-15 for normal use? - JeepForum.com
post #1 of 9 Old 01-11-2007, 02:59 PM Thread Starter
Lution
I've got stock wheels and 225/75-15 (i think that's correct) basically stock tires on my 99 Cherokee.
What should be the normal tire pressure for everyday use on the street? All 4 are reading around 22lbs right now.
thanks
-Lution
99' XJ Sport
Lution is offline
post #2 of 9 Old 01-11-2007, 03:25 PM
XJ's4-ALL
varies by brand my BFgoodich longtrails are 35psi some can be as high as 45 i always have mine at 35psi
XJ's4-ALL is offline
post #3 of 9 Old 01-11-2007, 03:51 PM
DementedXJ
DementedXJ's Avatar
1997 XJ Cherokee
i believe it is 30psi. You don't go by the tire's MAX pressure. The tire pressure should be inside the door jamb or manual of your XJ
2004 Dodge Dakota Quad Cab, 4.7l, 2" BB, bfg AT
1997 Mustang GT
DementedXJ is offline
post #4 of 9 Old 01-11-2007, 03:53 PM Thread Starter
Lution
i looked everywhere in the manual and i swear I couldn't find it.
Thanks for the info!
99' XJ Sport
Lution is offline
post #5 of 9 Old 01-11-2007, 03:55 PM
DamianDeBe
33psi is recomended for a '98
DamianDeBe is offline
post #6 of 9 Old 01-11-2007, 04:13 PM
XJ's4-ALL
best thing to do is go to the tire manufacturer's site look for your tire and it usually tells you the proper psi.
post #7 of 9 Old 01-11-2007, 04:31 PM
kg4kzv
1995 XJ Cherokee
Tire manufacturer recommended pressure not always right look in the drivers side door jamb as stated before. The reason is the tire maker does not account for vehicle weight and weight distribution. Just never go over max tire pressure on tire. Most of the time lower pressure is for better ride in that case you can get closer or at tire max pressure and get more mpg but sometimes pressure affects handling and wear. I had a link that told you how to find best tire pressure by checking it when cold then once warmed up after driving I think there was suppose to be 1 psi difference. But don't quot me on that.
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline
post #8 of 9 Old 01-11-2007, 04:51 PM
kg4kzv
1995 XJ Cherokee
Oops mine is on the lower back corner on the drivers door. 33psi front 33 psi rear for 1995 same as DamianDeBe has on his 1998.
Chris
kg4kzv is offline
post #9 of 9 Old 01-11-2007, 05:51 PM
ChairKey00
It's written on the tire. Once you find it, subtract about 6-8psi depending on the ride and handeling you want. This also allows for the 2-3psi you'll gain when the tires get warm.
2000 Jeep Cherokee Classic
2006 Kawasaki ZX-10R
2002 Honda Accord SE - Hers
2001 Nissan Maxima SE 20th Anniv. 5sp
2006 Pontiac GTO 6sp (12,500 miles)
1992 Chevrolet S-10 (224,300 miles...all original)
ChairKey00 is offline
Normal oil pressure for 91 XJ? hiram XJ Cherokee Technical Forum 4 10-14-2008 12:30 PM
Proper oil pressure? jeephack XJ Cherokee Technical Forum 4 01-23-2007 09:51 PM
normal oil pressure bmyohn XJ Cherokee Technical Forum 11 01-20-2007 10:30 PM
Normal Oil Pressure Vaj XJ Cherokee Technical Forum 10 01-04-2006 10:26 AM
Oil Pressure... What's Normal? XJ-NoDough XJ Cherokee Technical Forum 4 03-13-2004 11:01 PM
