#181 | |
what does filling the tube with sand do. should i heat the tube first?
#182 |
Sand in the tube will help lessen crimping of the bend
97 XJ Sport...Skyjacker 3", 31x10.5 BFG AT KO's, no rear & disco'd front sways, skids, Conferr rack w/custom spare/hi lift mounts, Hella 500FF & Harbor Freight lights, flareless & trimmed fenders 01 XJ Classic...rolled & totaled, but resurrected by someone else |
#183 |
yay
daf
1994 XJ Country *Rear-Ended gone * :( 1999 XJ Sport Chilli Pepper Red 4.5" lifted on 33's with tons of crap |
#184 |
Forum God
got the a-pillars done today, they are a full tube that go up from the floor and all the way back to the rear hoop, the b-pillar will attach into this when i get more t00b
also made a crossbar that mounts between the a-pillars but there was no way to hold it up there for a pic without a tack-weld, it has a bend in it angled towards the windshield. ![]() ![]() ![]() ![]() this is how i may do the top triangulating, undecided if i wanna do the triangle that way, or reversed ![]()
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me; Thy lift and thy tires, they comfort me. Thou preparest a spotter before me in the presence of mine obstacles; |
#185 |
Nice looking cage HM
cant wait to see this thing on the trails You kept the rear seat open for pass.? |
#186 | |
Forum God
right now that rear seat has to come out, it cant fold up to latch because the hoops in the way..i wish it worked. i plan to get some sort of seat back there...maybe a TJ rear or something, but thats in the back of my mind right now for the most part ![]() the real welding should be going on friday, right now its all just kinda sitting there haha, i gotta build the feet/tie ins
#187 |
This thing is looking sick. Does it run well enough to hit the trails when you are done with the cage?
#188 | |
either way IDEA http://www.corbeau.com/products/baja_bench/baja_bench.shtml ![]() much lighter if you dont run one at all, but you cant have more then 1 other person riding along is all |
#189 |
Milk crates work great and just tie whoever down back there with some rope.
Ok quick question in the cage. Why didnt you continue the A pillar bar to meet the bar you hav running to the trunk floor? It would have saved you from using that i guess more of a rain gutter tube. Get what i am saying
88 XJ Red | 5" of lift | Custom Bumpers | Black Rockcrawlers with 35x12.50 BFG MT's | Custom Rock Rails | Homebrewed OBA | Custom Roof Rack Loaded | Tube Doors | Play 4x4Country.CLICK HERE |
#190 | |
Forum God
, i wanted to get creative back there without being limited by it
#191 | |
Forum God
![]() they can meet as is, nothing welded or finalized yet, i just think it looks good like that/functions all the same as far as the milk crates...... awesome
#192 |
Youngin'
my vote is to take two buckets (from an XJ) and toss em in the back right next to eachother, it looks like theyd fit
2001 Dodge Ram 2500 SLT 4x4 5.9L Cummins Turbo Diesel "The Tow Rig" 1988 Jeep Comanche 2.5L 4cyl - 4 speed manual 2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker 6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering |
#193 |
Well I am new with cage building and I just know anywhere you have a main pillar coming you want some else from the floor to basically meet it there so you are creating any moments inside the cage. Aesthetically? I like the way you have it with the extra bar
#194 |
the tubes should meet at the rear tube as it is stronger the welding weakens the tube slightly and the tubes create a stronger point than it was originaly as well as dissipate force better as opposed to two paths it becomes one take a stick and push on it on opposite sides direcly across from each other then 2-3 inches appart and youll see what i mean so if you hit the front corner it would have a path straight to the rear pad as opposed to a bending force on the rear tube
it's a trick...get an axe |
#195 |
id like to see how you are tying that into the frame.
Thanks, Jack |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
