Programming PCM/ECU with VIN/Mileage - JeepForum.com
post #1 of 9 Old 02-14-2008, 01:35 PM Thread Starter
jrn1023
For those of you that have replaced your engine computer, did you have to take your rig in to get the VIN and Mileage programmed into the system? I have a '98 with what I suspect is a bad PCM. Before swapping it out, I'd like to know how much I'll be charged to have the thing programmed. That is, if I find a junk yard replacement. Anyone have any experience with this?
Thanks.
jrn1023 is offline
post #2 of 9 Old 02-14-2008, 04:35 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If you find the exact model year donor as your own Cherokee, re-flashing the computer is optional. You may even find that other model years will function just fine as well. Nobody else but us Forumpeople know that the mileage is also recorded in the ECM.
CJ7-Tim is offline
post #3 of 9 Old 02-14-2008, 05:51 PM Thread Starter
jrn1023
Thanks Tim. Now it's a matter of finding one reasonably priced. I plan to check with UPullRParts in Rosemount tomorrow. Tim, are you aware of any other places to check in the Twin Cities area?
jrn1023 is offline
post #4 of 9 Old 02-14-2008, 05:55 PM
alexrule123
alexrule123's Avatar
I put a 97 ecu into my 99 without an problems, your milage is not stored in the ecu
edit: Make sure the donor ecu comes from an xj with the same options your's has, such as auto or manual and if your's has cruise control or not.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #5 of 9 Old 02-14-2008, 06:04 PM Thread Starter
jrn1023
Thanks, the U-Pull I mentioned does have a '97 in stock. just not sure if the computer is still in it. I wonder why the units you get at say Rock Auto indicated the VIN and mileage need to be programmed. I'll keep the options in mind when looking for one.
jrn1023 is offline
post #6 of 9 Old 02-14-2008, 06:33 PM
alexrule123
With a 98 i believe you can use the years 97-99 and the only reason i am not suggesting to use years 00 or 01 is because the ignition system is different and they don't have distributors.
post #7 of 9 Old 02-14-2008, 06:51 PM Thread Starter
jrn1023
Yep, I also own an '01 and was tempted to use it to test the '98 but there is enough of a difference that I didn't want to risk ruining the running vehicle.
jrn1023 is offline
post #8 of 9 Old 02-14-2008, 07:10 PM
CJ7-Tim
CJ7-Tim's Avatar
Call U-Pull and see if they have any 97+ in the yard, the ECM is usually the first part to get taken. I deal with AAA (parent company for U-Pull and just next door ) and with John's Auto Parts in Blaine. My buddy just got a 98 ECM from John's for his 98 and didn't re-flash it, he just drove it home.
With the distributor-less ignition system I wouldn't try that.
CJ7-Tim is offline
post #9 of 9 Old 02-15-2008, 05:04 AM
CharBroiled
you dont need to flash it for it to run.
but getting it inspected is a different matter, depends on your states inspection laws, some may compare the VIN that the OBDII port gives to the actual vehicle VIN. why they would do that (if they do) is beyond me.
2000 Cherokee Sport 4.0L Selec Trac - mine - for occasional wheeling
2007 Patriot 2.4L FD I 4x4 - wifes - doomed to rarely leave the street
CharBroiled is offline
Programming keyless FOB cranfkev XJ Cherokee Technical Forum 16 05-17-2015 02:43 PM
Programming key fob COLOUXJ XJ Cherokee Technical Forum 3 04-23-2009 09:39 AM
Programming Key Fob for 01 XJ JeepXJsport12 XJ Cherokee Technical Forum 4 06-02-2007 02:44 PM
Programming a key fob? XJ01AB XJ Cherokee Technical Forum 2 05-18-2006 05:39 PM
Key fob programming chobes XJ Cherokee Technical Forum 1 01-03-2006 09:27 AM
