Quantcast Procomp Leaf Spring Packs (remove overload leaf for 2")? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Procomp Leaf Spring Packs (remove overload leaf for 2")?
Old 02-11-2008, 02:24 PM   #1
grizbait
I have this Procomp Leaf Spring Pack for an XJ (part 53111). Brochure says it's for 3.5" - 4" over stock lift setup (http://www.explorerprocomp.com/PDFs/07cat/44-51.pdf for description). I'm wondering about removing the overload leaf.
Pics are here:
http://i219.photobucket.com/albums/c...eafSpring1.jpg
http://i219.photobucket.com/albums/c...eafSpring2.jpg
Has anyone ever taken the overload leaf OFF and used this spring to achieve 2-2.5"? I wonder if it would be worth a try. Anyone done it?
grizbait is offline   Reply With Quote
Old 02-11-2008, 03:31 PM   #2
Paradise XJ
Consarn it!!
Paradise XJ's Avatar
1990 XJ Cherokee
Don't think it would hurt anything (except you wouldn't have an overload spring!!??[as if]). You could buy what you really want from somewhere else too.
If you took that bottom leaf off you'd have 3/4" less of a lift than the springs would offer anyway becaue the overload spring is flat (doesn't add any lift except for the thickness of the leaf itself, like a 3/4" block.)
I have 2 RENIX 4.0 Jeeps
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Originally Posted by fedx95 View Post
Try grabbing it and yanking and see if theres any play.
Paradise XJ is offline   Reply With Quote
Old 02-11-2008, 04:58 PM   #3
grizbait
Originally Posted by Paradise XJ View Post
If you took that bottom leaf off you'd have 3/4" less of a lift than the springs would offer anyway because the overload spring is flat (doesn't add any lift except for the thickness of the leaf itself, like a 3/4" block.)
Guess that's true - basically this leaf has little effect unless you bottom out the springs anyway...
Old 02-11-2008, 09:07 PM   #4
grizbait
I sent an email to the ProComp tech folks. Basically, they said 2.5-3" over stock is lift, is what you could expect.
Here's what they had to say. This from John Meeden (jmeeden@explorerprocomp.com), Products Manager at Explorer Competition Products, LLC.
"Depending on the weight the vehicle is carrying, the lift will be 2.5” – 3.0”.
Old 02-11-2008, 10:26 PM   #5
Paradise XJ
Consarn it!!
1990 XJ Cherokee
Yep, a 3.5"-4" Pro-Comp lift equals about 2.5"-3" after it settles in with stock shackles (still sags a bit).
Old 12-06-2009, 10:45 PM   #6
dirty97jeep
1997 XJ Cherokee
so pretty much your say that at first you will have a 3.5-4" lift but after a short amount of time it will settle to be the correct 2.5"?
dirty97jeep is offline   Reply With Quote
Old 11-29-2010, 01:11 PM   #7
c0ncEpT
1995 XJ Cherokee
They don't settle that much. I have them, shackles, and relocation boxes and it sits perfectly level with my front 5.5" springs.
They settle right into that 3.5" range from my personal experience.
95 XJ. Longarm'd, Geared and Locked on 35's
c0ncEpT is offline   Reply With Quote
Glock Forum
