Quantcast PROBLEM SOLVED - interesting fix!!!!!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > PROBLEM SOLVED - interesting fix!!!!!!!
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 12-27-2007, 10:35 PM   #1
mickdawg777
1995 XJ Cherokee
My post about 2 weeks ago (buried mile deep on here) "unknown problem, no solution" has finally been addressed and solved. If you can find the topic, you can see all the $300+ I spent on sensors and fuel pumps to address a hesitating and surging problem on a '95 chero inline six.
When I overhauled the engine, I installed an aftermarket camshaft. When I went farting around in the distributor today, i noticed that at 1st cylinder TDC, the rotor was about 3/8 of an inch off center from the contact in the dist. cap for cyl. no. 1. Looking at a crucial website on the net http://blog.hemmings.com/index.php/2007/11/28/hmx-countdown-to-ignition-indexing-the-distributor , I was able to determine that the aftermarket cam is a little off in the timing of the distributor. Since the dist. is non-adjustable in timing from the factory, I had to take a hacksaw to the mounting bracket to make it so that I could turn it 15 degrees counterclockwise to center the rotor. NO MORE RUNNING PROBLEMS!!
In conclusion, aftermarket camshafts WILL mess up the preset factory timing, so you'll have to readjust it yourself. After a massive headache and $300+ in throwing parts at it, I was shocked that I fixed it by taking a hacksaw to the distributor mount. I learned that in an electro-mechanical distributor, the rotor MUST be centered on the contacts in the cap so that the engine computer can have room to advance/retard timing within the rotor contact
mickdawg777 is offline   Reply With Quote
Old 12-27-2007, 10:38 PM   #2
lifted92xj
1992 XJ Cherokee
atleast you finally found your problem..like you said it was right infront of your nose..i wish mine was that easy but its never been rebuilt, i dont think
big lift, sick tires, awsome accessories, alot of custom work.
my jeep won the war, your honda mows my lawn
lifted92xj is offline   Reply With Quote
Old 12-27-2007, 10:56 PM   #3
Goldenknob
1992 XJ Cherokee
glade you found it... thanks for the info.
Goldenknob is offline   Reply With Quote
Old 12-27-2007, 11:18 PM   #4
mickdawg777
1995 XJ Cherokee
one thing is for sure, at 214000 miles, all those new sensors and fuel pump should keep my check engine light off and my wallet in my pocket for at least 60000 more miles... i hope!
Glock Forum
