Problem with Solenoid? Transmission is stalling - JeepForum.com
post #1 of 7 Old 03-21-2011, 07:50 AM Thread Starter
Myzery
For almost a month my 1997 cherokee would start slaming when I was driving around. It wouldn't do it often, sometimes I could drive it all day without it happening at all. But when it did happen it was really loud and forceful. Now my check engine light is on and my jeep isn't shifting properly. It feels like it takes forever to get out of 1st or 2nd gear and is making my life really difficult when I have to go up hills.
I plugged it into a diagnostics machine and the code that came up is:
Code P0753 (M), Transmission 3-3 shift sol/ transmission relay circuit. an open or shortened condition detected in the transmission 2-4 shift solenoid citcuit ( 4 speed auto. trans only)
I have no idea what do for this, but I know its probably an expensive fix, I think the jeep had this problem with its last transmission. Can someone please give me some advice here? I'd really appreciate it.
Myzery is offline
post #2 of 7 Old 03-21-2011, 08:05 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
- Faulty shift solenoid
- Shift solenoid harness or connectors
- Shift solenoid circuit is open or shorted
- Low transmission fluid level (check level on dipstick, but this cause less likely)
- Dirty transmission fluid (fluid should be red, and not smell burnt)
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 7 Old 03-21-2011, 09:19 AM Thread Starter
Myzery
I just got off the phone with aamco, he said it could be like between 600 and 1800 to fix it. 1800 if they have to rebuild the transmission. Im almost positive its the solenoid, but everytime i look up the symptoms of the problem it says that the car shouldn't be able to shift at all if the solenoid is messed up. Could this mean its electrical? I mean the car can still shift, but it just feels like it can't shift into overdrive. I'd truly appreciate if I could get any form of advice here. If the stupid mechanic trys to shark me here I'm probably just gonna end up driving this thing till it dies and getting a new car, and I really don't wanna do that.
Myzery is offline
post #4 of 7 Old 03-21-2011, 09:51 AM
jasonmason147
I can't speak for all aamcos but I wouldnt take it there. Bad our not they will most likely tell you its bad and will need a full rebuild. They told me that when mine was shifting funny and I took it home and dropped the pan and serviced it and it's been fine for the last 30k miles. So just be cautious with aamco.
jasonmason147 is offline
post #5 of 7 Old 03-21-2011, 09:56 AM
tjwalker
tjwalker's Avatar
I agree. I would find an "independent" transmission shop to take it to.
It is hard to say without more diagnosis and testing of the solenoids, but this could very well be an easy fix.
The OBD system is pretty good at leading you to the problem. And the odds are high that a solenoid replacement may take care of this for you.
tjwalker is offline
post #6 of 7 Old 03-28-2011, 12:40 PM Thread Starter
Myzery
Update
OKAY! You guys were completly right about aamco, they didn't care. They said all they could do was rebuild the trans for 1500. But today my Jeep completly shut off while I was pulling out of my street. When I restarted it the check engine light was no longer on, and now it's back to slamming. It's seriously just like it was before the check engine light came on. Can anyone shed some light on this for me cause I'm really confused. My brother said it's probably the relay or something like that.
Myzery is offline
post #7 of 7 Old 03-28-2011, 12:45 PM
hubs97xj
1997 XJ Cherokee
Here's a thread that might be of interest to you. I believe the info to test the solenoids is in there as well; on the off chance they aren't the problem, you're only out a tube of RightStuff/a gasket, and you might as well clean/replace the filter screen and do a drain-n-fill while you're in there.
http://www.naxja.org/forum/showthread.php?t=987463
hubs97xj is offline
cherokee , help needed , solenoid , transmission
Starter Motor Problem? Solenoid Clicking! Swiss XJ Cherokee Technical Forum 12 11-09-2012 03:28 AM
TCC Solenoid problem? 99WhiteXJ XJ Cherokee Technical Forum 4 07-20-2010 06:32 PM
Looking for a transmission solenoid? lilseth0014 XJ Cherokee Technical Forum 2 06-05-2009 08:24 AM
solenoid problem updatelee XJ Cherokee Technical Forum 4 11-07-2005 12:20 AM
