Problem with Rough Country control arm bushings - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Problem with Rough Country control arm bushings
Rough Country Lift Kits and Parts!The ULTIMATE "Selectable" Locker System! BroughIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-17-2009, 09:00 PM   #1
Amadeus3
1997 XJ Cherokee
So I have a 4.5" RC lift with fixed lower control arms with poly bushings at both the frame and axle end. I replaced them about 2-3 weeks ago because the old ones were shot and the arms were moving quite a bit and clunking on the frame end. Well it rode great for a couple weeks and now they are completely shot again. Haynes manual says the torque specs for the lower arms are 133 ft-lbs. I just tightened the bolts down pretty tight because I don't have a torque wrench but they weren't ridiculously tight.
So I talked to RC and they are sending me a new bushing kit for free. The guy told me not to tighten them down any more than 30 ft-lbs? Not sure about that, I mean they should make a bushing that will last at factory torque specs right? Anyone else have this problem? Thanks.
6.5" Rough Country lift, locked on 35x12.5x15" BFG KM's, Nate's 4x4 Slimline, Smittybilt XRC10, skids, random junkyard upgrades
Amadeus3 is offline   Reply With Quote
Unread 04-18-2009, 06:48 PM   #2
Amadeus3
1997 XJ Cherokee
so no one has any advice for me?
Unread 04-18-2009, 07:24 PM   #3
94xjstud
1994 XJ Cherokee
Do what rough country says. Test it out and let us know if it works. 30lbs seems alittle light for those bolts though.
94xjstud is offline   Reply With Quote
Unread 04-18-2009, 09:51 PM   #4
Amadeus3
1997 XJ Cherokee
yeah i just don't want my front axle to end up being my rear axle haha. OEM specs call for the LCA bolts to be torqued to 133 ft-lbs per the Haynes manual. Just seems like kind of a gamble.
Unread 10-26-2010, 05:33 PM   #5
jrr1631
I got two rough country lifts one on an xj and one on my tj the xj hasn't been off the dirt road but the tj bushings are shot to I tried getting ahold of rough country but they are just so great at getting back to you, they even sent me two different control arms for my lower on the xj and I got sick of jacking with them and used them I flipped not long ago and the little one bent pisses me off, but yes all their bushings stink I bought a set of poly bushings but they are to big can u give me an idea of were to get some good ones? I want poly, keep jeeping brother
jrr1631 is offline   Reply With Quote
Unread 10-26-2010, 06:07 PM   #6
BeepBeepGoJeep
1994 XJ Cherokee
when i did my lift i replaced all control arm bushings with energy suspension
[]IIIII[]
BeepBeepGoJeep is offline   Reply With Quote
Unread 01-14-2012, 11:38 AM   #7
FleXJ96
I know this is old, but what did you replace them with>? Rough Country says they don't sell bushings and that I need new arms
FleXJ96 is offline   Reply With Quote
Unread 01-15-2012, 10:23 AM   #8
jrr1631
I had to buy four new ones they cost me 100 bucks
Unread 01-15-2012, 11:02 AM   #9
97xjsam
Have you put any thought into switching to a felting or pol-carbonate bushing.
97xjsam is offline   Reply With Quote
Unread 01-15-2012, 11:24 AM   #10
FleXJ96
What RC is saying is that the bushing can't be replaced. As in no one sells them poly or other wise. Which just seems super strange. Unless its a one off size
www.4LOWphoto.com Jeep and off road photography
www.Florida4x4.org A place for FL offroaders to gather.
My XJ Build Thread http://www.jeepforum.com/forum/f22/silver-bullet-xj-sport-24s-31s-1398256/
Unread 01-15-2012, 11:47 AM   #11
Timo_90xj
Timo_90xj's Avatar
Dunno if RC changed their LCA design at some point, but the adjustable RC short arms I have on my ZJ (same arms used for XJ/MJ/TJ/ZJ) has OEM Clevite rubber bushings on one end, and the flex joints on the other. Should be no problem replacing the bushings with new ones.
IDK if the fixed arms are different or if the older ones were some sort of strange size no-one sells parts to.. Would sound really weird if you couldn't swap the bushings at all
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
Timo_90xj is offline   Reply With Quote
Unread 01-16-2012, 03:57 AM   #12
97xjsam
Sounds like its time to cut both bushing barrels off either end and switch to a heim and Uni ball
Unread 01-17-2012, 06:43 PM   #13
FleXJ96
Here is a shot of some of the ones that are trash and one that has completely come out. They measure 2" across. I was going to take to a Truck shop by my work and see if they have an opinion. It would just seem so strange to have a non replaceable rubber part that is essentially made to wear out. If any one has any thoughts please share. My budget is tight and I would hate to have to spend $130 on new arms if there is a cheaper bushing options on these ones given to me. He has a TJ so I have 4 arms, that's why you see 3 in the pic. It's the part number is the same as XJ arms. thanks
Unread 01-17-2012, 06:48 PM   #14
FleXJ96
Unread 01-18-2012, 09:15 PM   #15
97xjsam
So is it the same bushing in each arm that's wearing out? If it were me I would seriously consider a delron bushing to replace it. Delron is much strong and less resistant to wear. It squeaks a little so white lithium grease is a must. Are the current bushings urethane or vulcanized rubber?
