Problem with my 89' Cherokee Laredo - JeepForum.com
post #1 of 7 Old 03-01-2013, 11:15 PM Thread Starter
darthginger28
I am a new member to this site and only recently joined. I have used this site numerous times for the references in quick fixes to the minor problems on my jeep. I need help with my blinkers. The front blinkers and the rear blinkers and reverse lights are not working. They were working when I got to work and when I turned the car back on they didnt work. My brake lights have also stopped working. Any suggestions?
darthginger28 is offline
post #2 of 7 Old 03-02-2013, 12:11 AM
elwell401
First check fuses. Then other than that it sounds like a bad ground somewhere.
elwell401 is offline
post #3 of 7 Old 03-02-2013, 02:49 AM Thread Starter
darthginger28
I have already checked the fuse and its fine. What does it mean that I have a bad ground and how do I fix it?
post #4 of 7 Old 03-02-2013, 06:04 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Blower motor working?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #5 of 7 Old 03-02-2013, 01:33 PM Thread Starter
darthginger28
what is the blower motor? how do I check it?
post #6 of 7 Old 03-02-2013, 02:11 PM
Millermagic
Blower motor is the heater fan.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #7 of 7 Old 03-02-2013, 06:23 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Correct. The heater fan. If it doesn't work, it helps me to steer you in the correct direction for an accurate diagnosis.
blinkers , cherokee , laredo , lights , problems
