Problem with misfire on acceleration 98 4.0 - JeepForum.com
post #1 of 17 Old 02-05-2007, 05:32 PM Thread Starter
rbluhm
I have a 98 cherokee 4.0 that misfires on acceleration. Now it does it only after I have run
the Jeep (warmed it up) then after it sets for about 2 hours or so usually after I take off
from the first stop sign, it lasts for about 10 seconds. After that it runs perfect. The Jeep dealership has, done the following: changed TP sensor, MAP sensor, oxygen sensor, coil, distributer cap, plugs, wires, air cleaner, they have done an engine combustion cleaning and it still does it. They have done a computer recording of it when it acts up and have told me that the map sensor reading shows a drop in vaccuum. They are now scratching their heads wondering what to do next. The Jeep runs perfectly otherwise. Any help would be greatly appreciated.
rbluhm is offline
post #2 of 17 Old 02-05-2007, 05:41 PM
bee guz
Try tightening the intake maniflold, could be loose bolts, on the intake of the throttel body is loose, and sucking air, just a guess
bee guz is offline
post #3 of 17 Old 02-06-2007, 09:42 AM Thread Starter
rbluhm
I had the dealership check the intake and throttel body for leak and they said that they were tight. any other ideas?
rbluhm is offline
post #4 of 17 Old 02-09-2007, 08:51 AM Thread Starter
rbluhm
still a problem
My Jeep stopped doing it for 2 days after checking the intake being tight and throttle body being tight and fter 2 more combustion cleanings but now is doing
it again just as bad. My bill is getting huge and am ready to sell it but who's going to buy it like it is? Please help does anyone have an idea.
rbluhm is offline
post #5 of 17 Old 02-09-2007, 05:38 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Is the MAP seal on the TB tight? Is that the only code that is being thrown?
Have them remove the IAC (Idle Air Control) motor and clean the metering rod on it and the housing as well.
Maybe have them check the air temp sensor as well and make sure it is functioning properly.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #6 of 17 Old 02-11-2007, 12:48 PM
moroyoqui
is it misfiring or a stumble? try checking the fuel system. let me know what is going on....
moroyoqui is offline
post #7 of 17 Old 02-11-2007, 06:11 PM Thread Starter
rbluhm
It sounds like it is backfiring. But the popping sound comes from under the hood.
rbluhm is offline
post #8 of 17 Old 02-20-2007, 09:00 PM Thread Starter
rbluhm
not giving up
checked the MAP sensor seal looked good the dealership connected a fuel pressure guage and taped it to the hood hile I drove with and when it was doing its backfire thing the guage held steady so they are ruling out fuel problem. does anyone know if the coolant temperature sending unit could make things act up like this I am thinking of having them replace it for the heck of it.
rbluhm is offline
post #9 of 17 Old 02-20-2007, 09:05 PM Thread Starter
rbluhm
forgot to say
forgot to say they changed the air temperature sensor too
rbluhm is offline
post #10 of 17 Old 03-05-2007, 06:41 PM Thread Starter
rbluhm
TSB on 97 and 98 4.0
Just an update, I have found out that the was a technical service bulletin on my 98 4.0 which calls for heavier duty valve springs. It is a 3 hour job. I have had them replaced and it has been 2 days so far and all is well. Hope it continues.
rbluhm is offline
post #11 of 17 Old 03-06-2007, 04:17 AM
Rogo98Sport
Would You happen to have the TSB number??
I've been having the exact same symptoms with my 98 4.0
Rogo98Sport is offline
post #12 of 17 Old 03-06-2007, 06:31 AM
jlmclean
Hope the valve springs do the job but normally a weak spring would cause problems at higher rpm. I'm not saying that they are not the problem because a lot of times things don't work like you think they should. If the problem comes back, I'd check everything that has to do withe the fuel mixture, especially at low rpm. A lean condition will make an engine miss and sometimes backfire throught the intake. I don't think the TPS is adjustable on your engine but locate the specs for it and make sure you have the correct voltage at closed throttle. As I've found many times, just because you installed a new item, that dosen"t mean it's working up to specs. I don't think the manufacturers have high quality test anymore anyway. Especially China and Tiawan.
Good Luck and Post the results after you've driven it a couple more days.
jlmclean is offline
post #13 of 17 Old 03-06-2007, 09:12 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I am thinking heat soak and the fuel injector #3 heat shield TSB or the fuel pressure check valve on the fuel pump. Any problems with long crank times before starting? The gas in the fuel rail can vaporize and you get good old vapor lock (rough running) until you refill the fuel rail. Search the forum for these topics.
CJ7-Tim is offline
post #14 of 17 Old 03-06-2007, 01:14 PM
Rogo98Sport
I get the same problem but the Jeep runs fine when I floor it thus eliminating the weak spring issue since it would most likely occur at WOT...
Could it be carbon buildup on exhaust valves??? I know 99+Grand Cherokees have a TSB on that.
I think my next step in trying to find out what the f... is wrong with this thing would be SeaFoam treatment...
post #15 of 17 Old 03-07-2007, 07:08 PM Thread Starter
rbluhm
Third day results
Tonight it did it again, backfire through intake. The temperature here in Wisconsin tonight is 10 degrees. For the last couple of days it did not do it and the temps were in the 30's and 40's. I cannot remember it do it any time the temps were above 40. The good news is the temperatures are getting warmer with spring coming but the bad news is that I have done all the work on it without solving the problem and if the temps get warm soon their will be no way to test the problem till next winter, if I still own it. I probably should have posted the fact earlier that the cold weather triggers it. With this info does it narrow down the things that may be causing it? Thanks
rbluhm is offline
XJ acceleration problem garman18 XJ Cherokee Technical Forum 32 10-22-2008 12:10 PM
89' XJ acceleration problem Blazerman XJ Cherokee Technical Forum 1 02-10-2008 07:05 PM
Acceleration Problem liquidforceb069 XJ Cherokee Technical Forum 10 02-03-2007 02:56 AM
Acceleration Problem xupkid2 XJ Cherokee Technical Forum 4 01-06-2006 09:15 AM
Need help t/s Acceleration Problem! SoloHiker XJ Cherokee Technical Forum 2 09-25-2005 10:03 PM
