prestone coolant for jeep? - JeepForum.com
post #1 of 16 Old 10-18-2010, 03:28 PM Thread Starter
ski14dxb
can i use the prestone antifreeze/coolant that says no need to add water? because its pre diluted with water
ski14dxb is offline
post #2 of 16 Old 10-18-2010, 03:30 PM
h2oskikrazy
Yes, that stuff is mixed 50/50 and ready to pour in.
h2oskikrazy is offline
post #3 of 16 Old 10-18-2010, 03:44 PM
tangofox007
It's usually way cheaper to supply your own water.
tangofox007 is offline
post #4 of 16 Old 10-18-2010, 04:05 PM
scott_jeep
Yeah, but if you're carting it around in your trunk you only have to carry one thing, not two.
scott_jeep is offline
post #5 of 16 Old 10-18-2010, 04:13 PM
tangofox007
I am certain that I could figure out a way around that problem.
post #6 of 16 Old 10-18-2010, 04:40 PM
djb383
Why do people stop at 7-11 for whatever when whatever is way cheaper at Walmart?
djb383 is offline
post #7 of 16 Old 10-18-2010, 05:52 PM
Starboard M
I usually only carry one or the other. If I do need to add more or refill entirly its usually in an emergecy and I really dont care if my mixture is exactly right. I typically carry water since its cheaper, if it spills it doesnt make as much of a mess, and if I need to drink it I can.
Also, the only times I have overheated are during the summer and there really is no reason for coolant then anyway.
Not sure how many Walmarts or 7-11s are in the UAE, but I can get the premixed in just about any store I go to.
Originally Posted by NoVaHunter View Post
Honestly, its dicks like you that make unnecessary comments via the internet that have no impact what so ever.
Starboard M is offline
post #8 of 16 Old 10-18-2010, 06:55 PM
1armyguy
I just picked up 3 gallons of the 50/50 extended life mix for $8.50 at walmart and it had a coupon on it for a mail in rebate. Needed it because I was changing my thermostat and water pump.
1armyguy is offline
post #9 of 16 Old 10-18-2010, 07:08 PM
tangofox007
Full strength is $8.35 at the PX. Rebate is $7.
post #10 of 16 Old 10-18-2010, 09:16 PM
tjkj2002
2002 KJ Liberty
All prestone coolants are OAT coolants,AKA-Dexacool,and will gum up your cooling system.
You want true Ethylene Glycol or use the new Chrysler coolant which is a HOAT coolant(Zerex GO5),anytrhing else you will have issues down the road with your cooling system.
tjkj2002 is offline
post #11 of 16 Old 10-18-2010, 10:10 PM
djb383
Originally Posted by tjkj2002 View Post
All prestone coolants are OAT coolants,AKA-Dexacool,and will gum up your cooling system.............
A little info to back-up/support that statement (gum up your cooling system) would be appreciated. The Preston jug says "All makes, all models, cars and trucks, add to any color antifreeze". Seems like there would be plenty of lawyers hovering around if Prestone couldn't back-up their claim, or would gum up your cooling system.
djb383 is offline
post #12 of 16 Old 10-18-2010, 10:39 PM
tjkj2002
2002 KJ Liberty
Google "Dexacool" and find the big class action lawsuit against GM and all the nasty pics as that is what your adding to your system but GM did not get any $$$ for it.Oh and they did change there wording via the BBB made them as Honeywell could not 100% backup there claim as being a "all makes/models" coolant.
Then google OAT coolants(Prestone "all makes/models") and HOAT coolant and read for yourself.Ford even has a TSB about use of non-HOAT coolants and require the same HOAT coolant as newer Chrysler vehicles.
tjkj2002 is offline
post #13 of 16 Old 10-19-2010, 07:56 AM
tangofox007
Google "Dexacool" ...
One would hope that a Dexcool expert would know how to spell the name of the product!!!
You apparently have no idea what "true ethylene glycol" actually means.
I have been using Prestone antifreeze in my '88 XJ since since I drained the factory fill in 1990. I still have the original radiator and the cooling system seems to be working just fine. How many more years do I have before everything "gums up?"
post #14 of 16 Old 10-19-2010, 08:49 AM
dukie564
dukie564's Avatar
1995 XJ Cherokee
Make sure if you fix your own antifreeze/h2o that you are using distilled water not regular tap water.
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #15 of 16 Old 10-19-2010, 09:11 AM
djb383
................Oh and they did change there wording via the BBB made them as Honeywell could not 100% backup there claim as being a "all makes/models" coolant............
So which part of their statement did Prestone have to change? If a statement change was required, wouldn't u think Prestone would start with their website? How easy is that? It still says" All makes, All models, add to any color antifreeze".
djb383 is offline
Prestone Flush Kit WARNING MSHarnett XJ Cherokee Technical Forum 10 11-20-2010 05:14 AM
Prestone Flush Redrum8675 XJ Cherokee Technical Forum 4 04-03-2009 07:38 PM
Jeep Coolant Leak XJAl XJ Cherokee Technical Forum 9 07-05-2008 06:33 PM
My jeep is bleeding (coolant) georgesxj XJ Cherokee Technical Forum 5 05-29-2008 11:38 PM
Prestone Radiator Flush kit with Closed Cooling system atfrith XJ Cherokee Technical Forum 1 06-01-2005 04:18 AM
