Pressure Gauge on Transmission cooler line
#1 | |
Has anyone put an oil pressure gauge on their trans cooler lines?
What PSI should I get on the cooler lines? (I am assuming it would be pretty low) I thought I may do it in order to be able to tell if there is a leak in the system or out of fluid completely. ![]() Thanks.
#2 |
if you have a temp gauge it should also tell you if your getting low, it starts to get hotter the less fluid you have. but I think the AW4 has about 20 - 30 psi lines... they have actual transmission pressure gauges you can get also... at least I thought you could (edit: cant find one any more...)
NAXJA Member #2619 1995 Jeep Sport Cherokee 4x4 with an Auto and 4.0L B&M Transmission Cooler and Autometer Tranny Temp Gauge, Ruff Stuff Diff Cover on D30. Taraflex 1.5" BB (rear shackle only), HD Quadratec leaf springs, RE 3.5" front springs, OME Long shocks, JKS Adjustable Track Bar from K.O.R. Daystar Control Arm Bushings, Bushwhacker Flairs, Rhino lining along bottom trim, AGR PS pump with Cooler & Filter. Bored TB, APN Manifold, New Downpipe, Magnaflow High Flow Cat, Flowmaster Super 44. Dual Oil Relocation Kit running two K&N301 size filters, Autometer Digital Cobalt Oil Temp and Oil Pressure Gauge. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
