#1 | |
Preparing for new recovery bumper
After getting some minor damage to the front of the Jeep on my last outing, i decided it was time to make a recovery bumper.
![]() But first i needed to trim the lower sections of the front wings to allow the bumper to wrap around the sides. As there is a write up on Go jeep on how to carry out this mod, here is just a couple of picks of the process. ![]() ![]() ![]() ![]() ![]() ![]() With that completed i am now in the process of designing the bumper. I want to keep the bumper as neat as possible but it has to be able to accommodate a winch at a later date. Thinking of something along the lines of the one on Eric's XJ. ![]() ![]() I plan to make the centre section of the bumper (where the winch will be) out of 6mm (1/4) plate and the side sections out of 4mm(5/32). Also need to make new brackets to mount the bumper to the chassis out of 6mm.
#2 |
Made a start on the bumper.
Headed off early to my mates work to get some steel guillotined and folded. ![]() ![]() ![]() The centre section of the bumper is made out of 6mm(1/4). ![]() ![]() The end sections are made of 4mm(5/32) and folded in a similar way but with a taper. ![]() And then the corner sections. The gap at the corner will be filled in with a piece of rounded steel. ![]() When i got back to the garage with all the bits of steel i needed (dam, it was heavy ), i offered up the centre section and prepared to make brackets to mount it to the chassis.![]() The brackets are made out of 10mm(13/32). A little heavy but i had it lying around and decided to use it up. I kept them quite long to spread any forces evenly along the chassis rails. ![]() The over hang is kept to a minimum to help the approach angle. ![]() Thats as far as as i have got for now, more later. |
#3 |
Made a little bit more progress.
Got the end sections attached and filled in the hole in the corner. ![]() ![]() With the new bumper you get a much better view of the front tyres. Also there is less of a change of catching it now.![]() The sides of the bumper are trimmed so that it is a continuation of the wheel arch to aid wheel clearance. ![]() Even got the spot lamps refitted. ![]() Another night of fabrication One thing i have learned while making this bumper, is that when tack welding without a mask, you get a nice sun tan, OUCH!! ![]() |
#4 |
nasty man. wish i had a equip like that to break metal. I just started on my rear bumper cut it all out of plate(already had it layin around) with a 4" angle grinder. welded it all up with stick E6011 it about done ill post pics when complete. keep up the sweet metal fab!!!
Just got first 4x4 on 5/09. BB front, homemade rear shakles. New luk Clutch in ax-15. |
#5 |
Eventually got round to finishing the bumper.
I got the recovery eyes punched and welded into place. Also seam welded the entire bumper. ![]() Filled all the dents with filler and sanded down, then gave it two coats of Zink primer. ![]() Once dry, it was sanded with 600 wet & dry, then another two coats of gray primer. ![]() Managed to get a coat of satin black on the back before it got too late at night. ![]() The next day i got the primer all sanded and ready for the black. ![]() Three coats of satin black later and all i have to do is let it dry. ![]() Got it mounted to the Jeep and i'm very pleased with how it looks. It had pulled a little with the welding but wasn't too bad. ![]() I like the way you see lots more of the tyre now. ![]() ![]() I was able to keep it quite neat to the radiator but big enough to accept a winch at a later date. ![]() Even the corners turned out well. Amazing what body filler can do. ![]() Now, let me see, what next? A rear recovery bumper? |
#6 |
Pro comp mud terrains= no bueno
#7 |
Looks good, make me one now
2011 JK Wrangler - Sahara Tan SOLD 2012 JKU - White |
#9 |
#10 |
Great fab work, really nice job. Did you pick up the three steering box bolts on the outside of the chassis rail?
#11 |
#12 |
Great, should be a great recovery point and keep you from pulling your frame apart with the steering box!
#13 |
Nice work Moogie. I made mine in my garage with a junior hacksaw and a nail file
![]() ![]() ![]() ![]() It sounds as though you used all the mounting holes I did except for the 2 under the chassis rail that secure the anti-roll bar. ![]() |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
