#1 | |
Power windows not working
I have a '95 XJ. The drivers side window wasn't working, broken wire. So I fixed it and now none of the power windows will work. Pulling the little rubber piece off the back of the drivers control panel, I think the switches are fine. I have continuity between where the black wire connects and any one of the switches and when I engage the switch, I loose continuity. I then figured I wasn't getting power to the switch in the first place and so I used a circuit tester and I don't get any power to the switches when the ignition is on. The door lock switch is getting power but the windows aren't. I assume they are supposed to. I checked all the fuses and none were blown (the ones by the door and the ones in the engine compartment).
I'm guessing it isn't a broken wire in the door itself because the other doors don't work either. Anyone have any idea what could be causing this? Thanks for any help!
'95 XJ Last edited by jugglerbri; 03-01-2008 at 04:28 PM.. Reason: Just needed to be done. |
#2 |
my first guess was a blown fuse, but you said you checked those. Maybe a faulty ground somewhere? I would start chasing wires!
1994 XJ Sport 4" ProComp Lift with full leafs Rock Krawler Wheels/X-treme Mud Terrain 31x10.50 Banks Torque Tube w/Dynomax Super Turbo Cat-Back K&N Fuel Injection Performance Kit |
#3 |
#4 |
Being ignorant on wiring, would a broken ground at the drivers door keep the passenger door switches from working as well?
'95 XJ |
#5 |
What's the best way to check the ground. Would a continuity tester would be involved?
'95 XJ |
#6 |
Does the black wire coming into the switches at the door need to be hot? Also, anyone know which fuse to check? I pulled them all but perhaps I just missed it.
'95 XJ |
#7 |
Thanks for all the help everyone! I figured it out. It was a fuse. Apparently, there was one fuse in my fusebox that was metal and I couldn't see if it was blown or not (perhaps it was a breaker fuse?). Replacing it, fixed the problem. Whoohoo! I have windows up before the rain/snow tonight!
'95 XJ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
