Power windows + locks wont work - JeepForum.com
post #1 of 15 Old 10-16-2011, 06:54 PM Thread Starter
shadams
I have a 98' cherokee sport and the windows on the right side of the car can only be put down or up by the driver switches. it is quite annoying when riding with people in the car. Also the power locks do not work. Any help on solving this problem would be greatly appreciated.
shadams is offline
post #2 of 15 Old 10-17-2011, 09:38 AM
jnbenson
So I have a 99 cherokee sport, and it has the same problem with the windows, my locks still work!! Other things I have read on the internet, is it is the main control switch on the drivers side, IF it's not wire/fuse related. My mirrors don't work any longer either! I'm getting ready to pop off the cover and dive right in.
Anyone out there have any advise, for both of us!
jnbenson is offline
post #3 of 15 Old 10-17-2011, 11:40 AM
sirvs
I've got a 99 2 door and just hit this issue.
It could be multiple things. The windows could be (and most likely are) being blocked by the window lock relay on the driver side panel. 2 options, get a new board, or bypass the window lock switch. If I remember correctly, there is a thread in here about it, if not ill post again later ( I'm on my phone )
The locks not working could be a couple things. If your keys are in the ignition your locks will not lock with any door open(key sensor). For all these problems, it could be the boards.
Usually(at least mine) had leds in the switches that when it got power (and working) the leds were on a faint green.
Id sugest by starting with checking your switches. Get a DMM, pull the boards from the doors, and get a service manual. You can check the connectivity between the pins.
'99 XJ Sport - RC 4.5 X-series
Looking for tires...Ideas?
sirvs is offline
post #4 of 15 Old 10-17-2011, 12:55 PM
jnbenson
My jeep has the green LED lights too... sometimes they are "on" on the other window switches, sometimes they are not, either way, no one can operate the windows but me. THat, and my electric mirrors don't work any longer. So I'm thinking a new board. What is the official name for that part? Autozone has become my new favorite place to shop lately! :-)
jnbenson is offline
post #5 of 15 Old 10-17-2011, 01:02 PM
sirvs
I just call it the window/lock board
I actually pulled some out of some donor jeeps in a yard. The 2 and 4 door models have the same passanger boards in 2 and 4 door models.
I still recommend testing the pins on the boards, they could be fine and the window lock on the driver door is blocking all of them.
Ill take a look at the parts when I get home to see if they have numbers and whatnot for you
sirvs is offline
post #6 of 15 Old 10-17-2011, 01:11 PM
jnbenson
That would be fantastic! Thank you.
jnbenson is offline
post #7 of 15 Old 10-17-2011, 02:59 PM Thread Starter
shadams
Thanks guys! I need to go to the junk yard for some other parts I'll check out the boards too.
shadams is offline
post #8 of 15 Old 10-17-2011, 03:01 PM
banndit
I had the same issue w/ my power windows. I ended up solving it by spraying the switches out with electrical contact cleaner, especially the lock out switch. Spray the switch, push it multiple times, spray again, etc. I did it about 10 times and now all my switches work.
good luck.
its a Jeep thing...
banndit is offline
post #9 of 15 Old 10-17-2011, 05:28 PM
LEO_WRANGLER
In my Jeep's case (98 Cherokee), the power locks 'sort of' work. I hit the master lock switch and all the doors will lock or unlock -- EXCEPT the driver's door, which makes sort of ringing whining sound, with no movement of the lock. I can lock it manually and that still works.
I haven't disassembled the doors on this vehicle. Could someone point to a thread or writeup that describes this procedure?
Thanks,
James
LEO_WRANGLER is offline
post #10 of 15 Old 10-17-2011, 05:50 PM
AmbuGrl
AmbuGrl's Avatar
Start by checking the wires between the door and the body (remove the boot to access them). You may have cracked or broken wires, which is common. If that doesnt help, here is a write up that may : http://www.jeepforum.com/forum/f11/f...ummies-459934/
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #11 of 15 Old 10-17-2011, 07:35 PM Thread Starter
shadams
Thanks,
James
I do not get any clicking or buzzing when i hit the lock switch...i manually lock all my doors it gets anoying
i checked all the wires they seem fine but thanks i will check out that write up.
also i think my radio is wired up wrong...when i turn the nob down the volume goes up and vice versa. Come to think of it all my wiring seems to be wrong. Anybody have any advice on the radio??
shadams is offline
post #12 of 15 Old 10-17-2011, 10:03 PM
sirvs
Not a problem
So I grabbed one of the modules I have. The module number is 39754D with a UPC(or some other code) that is 56009506AC.
I did a quick google and came up with this
Just to give you an idea what the passenger ones look like.
The driver side changes for the 2 door or the 4 door cherokee (basically the number of switches installed on it, the wiring is all the same).
I also took a look in a service manual. you can test the continuity between pins on the lower (larger) pins 9 and 10 when the window switch is up and then 2 and 10 for the window switch to be down. Dont quote me on those, but Im pretty sure its right. This can tell you whether your switch itself is working or not for the window. If it is working, your issue could be anything...
sirvs is offline
post #13 of 15 Old 10-17-2011, 10:15 PM
sirvs
Thanks,
James
Hey James,
It sounds like another issue I just had. Mine would periodically work, for some reason. Almost every time I hit either lock or unlock, I would get a high pitch whining noise. Like the motor was going, just never catching.
I just replaced the lock motor. But there is always an issue with the simple task :-P
The lock motor is actually attached to the door latch. Its actually very easy to fix.
Lemme give you a quick write-up of it from memory. Im not sure if there is a thread about it or not.
1. Take off your door molding
2. Take off the lock motor wiring
3. Disconnect the locking bars and the latch bars
There should be 4 I believe.
Inside Handle
Inside Lock button
Outside door push button
Outside Key lock
4. Take off the 3 bolts right beside the latch in the door jam. I believe theyre star bits but dont quote me on that.
Thats it, it should be free.
When you put in a new one, compare it to the one coming out. There is a screw on the top that adjusts how far up or down the latch can go. This needs to be about the same otherwise, youll have issues closing your door
I grabbed my new one from the junkyard. Works well so far, and no more motor whining.
sirvs is offline
post #14 of 15 Old 10-17-2011, 10:19 PM
sirvs
So...3 posts in a row. Go me!
I ran across the thread about
1. Removing the door panel
and
2. Adding the splice to bypass the window lock switch
Thanks itasor for the write-up
sirvs is offline
post #15 of 15 Old 10-18-2011, 07:49 AM
jnbenson
THank you again! :-)
jnbenson is offline
all four power windows wont work can any one help apalmer XJ Cherokee Technical Forum 5 05-13-2011 03:00 PM
replacing manual windows and locks with power windows and locks iaml3lue XJ Cherokee Technical Forum 8 01-06-2009 06:00 PM
Power windows/door locks work intermitently kwd1975 XJ Cherokee Technical Forum 0 12-30-2008 08:39 AM
wont start, power door locks randomly work, keyless doesnt work Eric1080 XJ Cherokee Technical Forum 2 12-09-2008 07:40 PM
Power locks and windows philr XJ Cherokee Technical Forum 5 10-20-2006 03:52 AM
