power window lock out switch question
| Truck-Lite's New LED Headlamp Series | Ruffstuff Axle Simple Swap Kit! | Spartan Lockers FREE SHIPPING Excellent Prices |
#1 | |
Is the power window lock out switch a separate switch from the driver's side switch panel? Or is it a complete assembly with the lock out switch and window switches?
Thanks.
99 Jeep Cherokee Limited |
#2 | |
I assume you are having the infamous lockout switch failure issue so common to 97+ models. The fix is either to jumper around the switch permanently, or to open up the switch and "rebuild" the contacts inside the switch so they are more durable. Either way, it's a PITA, but there seems to be no other solution.
AZ-Jeff 1992 XJ 2" lift -- RIP 2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
