Power window fell down - JeepForum.com
post #1 of 22 Old 11-30-2006, 07:58 AM Thread Starter
David K.
Driver power window fell down today after paying toll. I can hear the motor still works. So, I think that it just fell of the track. I did hear a small crack/thud type of sound when it happened a hair after the window got to the top.
Is there a way to save myself pulling the door apart or does it have to come apart?
David K. is offline
post #2 of 22 Old 11-30-2006, 09:15 AM
AZ Jeff
2014 JK Wrangler
The window regulator is broken. It can be repaired if you are clever, or replaced with the new/improved design.
In either case, the door panel must be removed to gain access to the regulator.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 22 Old 11-30-2006, 01:17 PM
Croyle00XJ
2006 XK Commander
The same thing happened to my pass. window. Don't what ever you do take it to the dealer. The one down here in West Palm FL. said it would cost $470 to replace the regulator. If you can do without the vehical for a week order a cheap one off the internut or luck out in a junk yard. I lucked out and had a guy come to my house with the part for cheap. The door panel is only 3 or 4 screws and a standard screwdriver should do the trick popping it off! It's not hard at all. Good luck pal, it's a sucky situation!!.....you can always break out the plastic bags and duct tape them up, chicks dig it!! Good luck pal!
Croyle00XJ is offline
post #4 of 22 Old 11-30-2006, 03:55 PM Thread Starter
David K.
I have the door panel off and thought that I could find something broken...That isn't the case. What is the regulator? that needs fixing/replacing? There is much less in there than I thought. I can hear the power working but nothing moving.
Thanks
David K. is offline
post #5 of 22 Old 11-30-2006, 04:53 PM
03silvers
the regulater is the aluminum track the window rides along...goes up and down in the door....unbolt and remove then replace
99 xj sport
03silvers is offline
post #6 of 22 Old 11-30-2006, 06:09 PM Thread Starter
David K.
thank you, for now I used 3 zip ties to keep the window up so it can be driven while i track down the regulator. How much should I expect to spend? Say, junk yard vs stealership? Is it worth it to go to the aftermarket for this type of Item?
David K. is offline
post #7 of 22 Old 11-30-2006, 08:49 PM
isenegger
isenegger's Avatar
$280 from chrysler or about $100 or so from a junkyard. the only bad thing about the junkyard is just that....theres is old too and will break again like yours. there is a sticky about removing it and repairing it with cotter pins. which im going to try to do as well this weekend.
http://jeephorizons.com/tech/xjwindow.html
1996 Jeep XJ, 4.0L AW4, NP242, 69k mi, Rough Country 4.5" 31" Procomp Xtreme Mud Terrains,
isenegger is offline
post #8 of 22 Old 11-30-2006, 08:52 PM
stock777
look on ebay for a new regulator, i payed 120 and found one that night for 20, dang it was already installed by then, mine went at 90k miles but i use my windows all the time
stock777 is offline
post #9 of 22 Old 12-01-2006, 05:39 AM Thread Starter
David K.
Does anyone know what part of the regulator attached to the broken teeth?
David K. is offline
post #10 of 22 Old 12-01-2006, 06:18 AM
bridgman
i paid $35 bucks for one in the junkyard
bridgman is offline
post #11 of 22 Old 12-01-2006, 06:40 AM
Rasalibra
i have a similiar issue i guess, only i have manual windows. it didnt just fall down however when you crank it down you can only go down 1/4 of the way to the bottom before it gets stuck and when u want to put it up you have to pull the window while your cranking the handle and it will come up and crank up like nothing it feels as though something is stripped. Does anyone know whats causing this.?
Rasalibra is offline
post #12 of 22 Old 12-01-2006, 09:37 AM
AZ Jeff
2014 JK Wrangler
That piece CANNOT be purchased by itself, unfortunately. (I have heard of guys repairing these, but I don't know the details.)
AZ-Jeff
AZ Jeff is offline
post #13 of 22 Old 12-01-2006, 09:53 AM
h2oskiier222
I replaced the regulator on my '98 drivers window and it was about $140 from the stealership. It came with a new motor and track and bolted right in.
2001 Cherokee Sport 4x4 4.0L NV3550, NP231, Ravine Wheels w/ 235 Michelin LTX A/T, Factory Up-Country
2002 Ford F-250 4x4 xlt SC SWB PowerStroke Diesel, 6spd, 4" exhaust w/ aero turbine and 5" magnaflow tip, afe stage 2 intake with PG7 filter, PacBrake PRXB Exhaust Brake
h2oskiier222 is offline
post #14 of 22 Old 12-01-2006, 10:29 AM
Rafa
Just for references, I got quoted $190 for the complete regulator and motor at the dealer in FL. Mine is about to kick because it is grinding when the window reaches the top.
Rafa is offline
post #15 of 22 Old 12-01-2006, 11:27 AM
XJHERO
XJHERO's Avatar
I was going to have mine fixed until the service counter guy told me it would be $350.... Fudge that. Someone needs to write to the manufacturer and tell them to produce just that stupid little threaded plastic dealy. Thats all I need for mine. Lets see... 350 for small piece of plastic..... me thinks not!
98 XJ.
4.0 HO - AW4 - NP 231 - DANA 30, CHRYSLER 8.25
4.5" RE SUPER FLEX KIT, 32x11.50 BFG KM's
DIFF GUARDS, ENGINE AND TRANS SKID, CB
XJHERO is offline
Driver side window (power) "fell" and now won't work grovesb2 XJ Cherokee Technical Forum 8 06-01-2011 11:52 PM
xj window fell xjinvail XJ Cherokee Technical Forum 6 07-08-2008 11:40 AM
Power window/Door lock controls fell inside door CapaJeep XJ Cherokee Technical Forum 0 06-22-2008 02:58 PM
rear window fell out, what to do?? TwistedcaB- XJ Cherokee Technical Forum 11 05-18-2008 01:01 AM
My Window Fell Down / Broke!! Help ronstar2 XJ Cherokee Technical Forum 5 01-06-2004 12:31 PM
