Power Window falls down on its own, and wont go up.... and its COLD! - JeepForum.com
post #1 of 14 Old 11-27-2006, 03:15 PM Thread Starter
Xride
Today getting into the parkade at school I go to put the window up and it gets to the very close to the top and then I hear a click kinda sound and the window drops about half way.
So now the power window switch wont move it up or down. But I can move it by hand.
Is there a way I can jam the window up without taking the door apart?
And what would the problem be?
Its WAY to cold to have my window down, -22C plus blowing snow making it feel like its -40C.
Help Please.
99 XJ, black, 4x4, NP231, 8.25 rear. Fully locked.
5.5" long arm lift, 35x12.5x15 Kumo KL71MT
Xride is offline
post #2 of 14 Old 11-27-2006, 03:28 PM
AznDrgn
Sounds like you either have a bad regulator, bad motor, bad switch, or it just fell off the track. Whatever it is you have to open the door panel to find out and to fix it.
'87 Jeep Cherokee Laredo 4.0L, NP231, AW4, 5.5" lift, s10/waggy/XJ bastard pack, 7" fabtech TJ coil springs - Weekend play thing
'83 Porsche 944 2.5L Callaway turbo - Daily driver
'81 Porsche 924 - Custom EFI and forced induction project
'83 Porsche 944 2.5L - Sold
'78 Porsche 924NA 2.0L - RIP
AznDrgn is offline
post #3 of 14 Old 11-27-2006, 03:38 PM
h2oskiier222
The same thing happened to my 98xj and it turned out to be a bad regulator. It took about two hours to put a new one in and the local stealership had one on hand. For the time being you could use duct tape to keep your window up.
2001 Cherokee Sport 4x4 4.0L NV3550, NP231, Ravine Wheels w/ 235 Michelin LTX A/T, Factory Up-Country
2002 Ford F-250 4x4 xlt SC SWB PowerStroke Diesel, 6spd, 4" exhaust w/ aero turbine and 5" magnaflow tip, afe stage 2 intake with PG7 filter, PacBrake PRXB Exhaust Brake
h2oskiier222 is offline
post #4 of 14 Old 11-27-2006, 03:50 PM Thread Starter
Xride
Damn, I can hear the motor going when i use the switch, but nothing happens.
I didnt want to open the door, its always a pain in the ***.
If I open the door would it be easy to jam it so it stays up at least?
Xride is offline
post #5 of 14 Old 11-27-2006, 03:58 PM
sean883
I took a couple pieces of paper and kept folding them till it was nice and fat. I then stuck it between the window and the inside seal. Kept the window up for about 2 weeks until i could get it fixed.
Originally Posted by PhilipJ View Post
Your ego fits, the XJ should be fine with room to spare.
sean883 is offline
post #6 of 14 Old 11-27-2006, 04:12 PM
Bryson
Bryson's Avatar
This happened to mine a few months ago. The actual push rod that moves the glass up and down broke off from the actual window.
99 chilipepper red XJ: Race car tow rig. Turbo project in the works.
Head of Core production -
Owner of Boostwerks.com
Website in development.
Bryson is offline
post #7 of 14 Old 11-27-2006, 06:23 PM
airtech2309
about a hundred bucks from the dealership for the whole window regulator kit. shop around if you can.
airtech2309 is offline
post #8 of 14 Old 11-27-2006, 06:55 PM
patchouli
Do not try to pull it up with needle nose pliers. I did this, and broke it.
Turns out it was just off the track. I got a new window to the tune of 145.00. That sucks.
patchouli is offline
post #9 of 14 Old 11-27-2006, 06:57 PM
madrabbitt
madrabbitt's Avatar
go to a drug store and get two suction cups. push the window up by hand and put them as low as they'll go, jam them into the black bottom trim. it'll keep the window up.
thats what i did on my old POS oldmobile when the back window kept sliding down on the freeway.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #10 of 14 Old 11-27-2006, 07:21 PM
isenegger
isenegger's Avatar
mine did this yesterday....i got a NEW regulator and motor today for $62.00, yea shop around.
1996 Jeep XJ, 4.0L AW4, NP242, 69k mi, Rough Country 4.5" 31" Procomp Xtreme Mud Terrains,
isenegger is offline
post #11 of 14 Old 11-27-2006, 08:05 PM Thread Starter
Xride
ok I went down to jam it and it had fallen all the way down
So I busted out the tools and opened the door up, 20 minutes and 17 zip ties later that window isnt going ANYWHERE.
I dont really know what is broke because I couldnt get the part that opens the door and locks it to come off the door panel, but it came off enough for me to work around.
Xride is offline
post #12 of 14 Old 11-27-2006, 10:55 PM
EricsXJ
The Post man
EricsXJ's Avatar
good find for that price. Did it replace the plastic tab that broke with a metal one?
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #13 of 14 Old 11-27-2006, 10:58 PM
EricsXJ
The Post man
EricsXJ's Avatar
Its common for the bracket that holds the window to break off right where it attaches at the track. You need a new window regulator just like isenegger, and I've had the same thing happen to both my front windows in the past.
Eric
My website -
EricsXJ is offline
post #14 of 14 Old 11-27-2006, 11:39 PM
isenegger
isenegger's Avatar
yep it is metal and made by DORMAN. i work at Oreilly Auto Parts and that is who we order new window motors and regulators thru. also they make nuts and bolts as well. very good quality. none of this mopar $300 crap. normal price was about $100 for regulator with new motor no cores at all.
power window wont change polarity?? xtremexj59 XJ Cherokee Technical Forum 5 05-31-2009 09:59 PM
Power window switch wont work CherokeeErik XJ Cherokee Technical Forum 5 05-30-2008 01:35 PM
Power falls off at 3/4 throttle. Rich or lean? TheEddie XJ Cherokee Technical Forum 1 07-11-2007 09:32 AM
Driver window falls down when cranked all the way mrmateo XJ Cherokee Technical Forum 10 05-13-2006 06:01 AM
help key wont turn in cold cold weather asjeep XJ Cherokee Technical Forum 5 12-08-2005 10:00 AM
